stroked340
Time to change the fluid and filter what brand are you guys that race regularly using???..
What ever is the cheapest Type F I can find. Works just as good as the expensive snake oil.
Walmart carries a brand that is supposed to be the replacement to use where the original called for was the old Dexron III. Works good for me in my A-904..I don't use type F.....Dex/Merc III is all I use in my old mopars....That F is for Fords
Super Tech, Auto Transmission Fluid, for those requiring Dexron III. Walmart Stores, 2.84 /qt. hard to beat.Walmart carries a brand that is supposed to be the replacement to use where the original called for was the old Dexron III. Works good for me in my A-904..
That's what I use with no issues 303 hyd fluid I do put in two quarts of dextron just to dye it red to see on the stick 5 gallons of 303 run under $30 usually.I've heard of some people swear by using tractor hydraulic fluid. I use a type F/ dexron mix myself. Or whatever's on the shelf.
Bought a converter for my poor old diesel Ram, from a man who uses 30 non detergent motor oil in their racing trans. It doesn't seem to matter whats in an automatic, as long as it lubes the thing.
Same here.John Deere hydraulic fluid with a little trans fluid to give it some color.
Walmart type f
