440,headers with a 1969 barracuda
chadf
Guelph Ontario Canada
Quick question for you barracuda guys. I am going to look at yet another 69 barracuda..car comes with a running 1967 440. A really mild build. Anyways i would like to put a 4 gear in this car if i get it..the fellla that has the car now said nobody makes headers that drop between the rails for a big block 4 speed car. Said i would have to run fenderwell headers..
Why not try Schumacher headers?
They offer them modified for a 4 speed or you can do it yourself, there is a how-to on here with some good pics from a few years ago.
Yep, that's what I have for barracuda. Now mine is a 383 & I still had to mod the headers to fit a 4spd. I posted my mods on hear some time ago with pictures.
Cawley i will have to dig for you posts.l and check it out.. the offer on this deal just sorta fell into my lap and came about pretty quick so I really havent had time to explore the header option. I figured you guys would know best..but i can also buy the car with a 340. But i like the 440 idea just a bit better lol
If its a good deal heck why not. Yea I wouldn't chop up the inner fenders just for headers.
I'm using TTI headers in my Formula S 383 4-speed. Some mod done to the clutch linkage, thats all. No probs. But I don't know, maybe I was just lucky.
Get rid of the factory clutch linkage and go hydraulic. Very easy to do and no linkage to mess with.
Couldn't agree with this more. When I had my 340 4speed that damn linkage and Zbar always gave me *** aches.
I agree, go hydraulic//mild build right ??
My sig - 69 Dart GTS, Edelbrock crossram and aluminum heads on a 440 4 speed, Anson steel bell housing, 11" clutch, V-gate shifter, it's a ***** to install the Z-bar. The headers are TTI, fit excellent - spendy though if I recall. I used a Robb MCC starter (clockable). I use a remote oil filter. No power steering. Moroso center sump pan with a regular pick up. MSD 6AL ignition. Edelbrock fuel pump and filter. I used Schumacher adapter mounts with a steel biscuit on a 340 K member. I don't have the specs handy, but its a Lunati roller cam, with Comp lifters and PRW rockers and Smith push rods. The carbs are a pair of 500 CFM Carters. Mini tubbed , 8.75 with 3:23 S.G. The basic engine is from 69 Charger, pretty much stock components. Aluminum H2O pump, 160 degree T-stat, 15 lb rad cap and a 3 row copper rad with a factory 7 blade fan.
I have since seen a couple of nice adaptations on here using factory mini starters. The BBD A body 4 speed installation is one of those understated applications that until you go through the pain, you really don't appreciate what you are looking at.
I am sure I will have lotsa question..i thought about using a front motor plate to put the 440 in with...i am pretty confident either way that it ISN'T gonna be easily accomplished
