osxdos
72' Duster / 360
I tried jb welding the switch and left the ziptie on itSo now you need the ignition switch, and the key cylinder that you pounded the screwdriver though.
I let it sit for 10 hrs, it lasted three ignition hits, then broke :/
Back said 4-6For future reference, 10hrs is nowhere near enough time for JB Weld. Give that **** 24 at least.
Back said 4-6
Ah, I unhook the battery once its started, all fuses getting prpor amps, everything worksCarry a fire extinguisher
Jesus H Christ . Just go get the new switch so you dont mess anything else up..Ah, I unhook the battery once its started, all fuses getting prpor amps, everything works
I can't till like end of weekJesus H Christ . Just go get the new switch so you dont mess anything else up..
