QuickDart360
Stock stroke is the way to go! Every build now is a stroker. Nice to see a stock stroke free reving smallblock make quick zippy power based on rpm power!!
Order one up and I will build it. I'll even make more than that.build a stock stroke 600hp 383. that would be sweet.
Personally I like strokers, IMO gobs of torque from way down low and can pull higher gears for cruising. I see a lot of guys comment on 340's and rpm's. How many rpm's are you guys turning your street driven pump gas 340's? My 434 has a 4.125" crank in it and it's as quick reving as any 340 I've owned. I think it's a common misconception that long stroke motors are slow reving.
my suggestion is to do whatever you need to do cubewise and meet your power goal, but on 87 octane cheap stuff.........I HATE having to fill up with a dollar a gallon more premium fuel.......
What?.......I remember the Sales Ads back in the late 60s saying that the 340 was a high winding motor..........
so octane requirements have no effect on power?the original post is "the same power" regardless of cubes.
for that many hp, you need to increase the cubes as much as possible to keep the rpm in a range the valve train can live a long happy life. A 340 inch motor would need about 7000 rpm to make an honest 600hp. Obviously a 416 would need a lot less. If this motor is to see street duty it is real important to go big, for obvious reasons.Im going to build a 340 here pretty soon. But what way to go? Any size I choose it will make around 550HP. I know torque will go up as stroke goes up, but any way you slice it its going to make good power. Lets here what you guys/gals think? Im kinda leaning toward 340ci.
Im sticking with the 3.31, 3.58 or 4.00 stroke, nothing fancy and expensive. Im with you about strokers, I do a lot of them. Its hard to beat the power they put down. But there is something about a high rpm screamer too. It will be up for sale afterwards, so Im trying to get a good pulse of what the people want. I may lean toward the 3.31 stock stroke, but if the masses say STROKE THAT MOTHER, then I will.
Keep it coming, I love the discussions.
Business is business. If it's a gamble regardless of the direction, thinking as a business, limit the odds and go for the biggest market. Strokers are "overdone" because a boatload of people want them (still).
so higher octane offers no more horsepower potential in an engine?hi octane is not more powerful...just more stabile
