Oh, I'm sure, lol! I'm thinking more of a "gotcha", than a punchline.......I would still like to see a pull w/a 650DP...........My guess here(from reading his previous posts) is that he knows exactly what the hell he's doing. I'll wait for the punchline before I tell him how to do his job.
More the cam than the headers.imoCam and headers.
Not much mystery there.Oh, I'm sure, lol! I'm thinking more of a "gotcha", than a punchline.......I would still like to see a pull w/a 650DP...........
Obviously that combo isn't intended for hi rpm, the "gotcha" is the heads w/300CFM, everyone expects the intent to be max RPM/HP with them..........
what it proves is what I've been saying since I was out of High school, higher flowing heads allow you to run a smaller cam to make the same HP,
actually improving lower rpm numbers, as long as they are efficient(not way oversized ports i.e.boss 302 fords etc.)
Cummins killer lol
i've seen multiple posts of guys saying they made best power in the 31* timing range with magnum combustion chambers.
curious to see the vacuum numbers and the cam specs.
also what is the cranking pressure?
looks like a badazz truck motor...
Cam and headers.
HP was still climbing and 484hp/544tq is no slouch. I am impressed.
Small cam and ultra conservative timing too. You might have a little more on the table with a timing change.
Seems like a well tune engine to me.
I'd like to see a pull with a smaller carb, maybe a 650, then bigger headers on another.
Laugh if you want but I'd be interested in what it does for torque numbers.
It gained exactly 2.3 HP from 5000-5700 and only 9.8 HP from 4700-5700 RPM so I wouldn't say it was still climbing.
He only posted lift numbers. Maybe Ramm is doing a mind squeeze on us and it's some kind of a low lift cheater grind just to make us go off the reservation. IMO, it's way down on lift.
From my experience, that power curve will make the car run the same ET whether you shift at 5000 or 5700. I'd like to pile another 50-60ish and run it to 6500 RPM.
BTW, I think I asked this before, because it seems that's your dyno carb....what Venturi size is that 750? How about the throttle bores...what size? That means more to me than advertised CFM rating.
Chebby,World Product Heads,close to the same squeeze.......liked 26deg best on pump premium..........................i've seen multiple posts of guys saying they made best power in the 31* timing range with magnum combustion chambers.
Something's making the intake side struggle more than it should have to. I look forward to seeing the cam card.
You mentioned a truck oil pan soooo is that the reason for the mild cam? Maybe building a mean stump pulling engine for a 4x4??
I think the "lack of power" is sort of a slight combination of things. I think it's funny it's considered less than stellar results given you got over 100% VE. Which is considerable in itself.
The carb is a hair on the small side.
The cam is a hair on the small side.
The headers are a hair on the small side.
1.6 rockers would be nice.
Over 100 VE is great. Curious what your dynamic compression ends up being.
With you mentioning sub 500 lift cam. And your current power placement. I'm going to guess the cam is FTH in the 220 duration area? I would be curious to see a pull to say 6k rpm. I know it won't make more power. Given where the max torque is. But I would be curious to see what the powerband does.
What ignition setup are you running?
In either case. That's a buttload of torque and down low. That thing would be very hard to control on street! Curious to see what cam is in there.
\drop in a MP .590 cam and retest. plug everything into a shareware desktop dyno program and see the difference on that simulator, very useful tool if not being a little generous on HP ratings.
