414 stroker dyno
Charger383
Member
Hi guys!
Just had my 414 (360 stroker 0.060") in the dyno.
Must say I am amazed over how much power these engines produce!
You can see a vid of the pull here: [ame="http://www.youtube.com/watch?v=_KtTgpmQi3A"]http://www.youtube.com/watch?v=_KtTgpmQi3A[/ame]
And for the numbers?
481 clb-ft and 482.9 hp on the engine
712.2 lb-ft and 725.5 hp with the nitrous
Hey Charger, I was always a big block guy. Then I wanted something a little easyer to work on in the car. I built a 414 small block with Eddy heads and air gap intake, comp cam with hydraulic rollers. I'm impressed with all the power this thing has. Not sorry at all going to small a block. The car is a blast to drive. Plenty of power for my 68 Dart. Street driven only.
Thanks for your replies, guys! :)
Im using a Edelbrock plate system. Used the 85/89 jets that was supposed to give 200 hp.
As you can see in the video, my headers are not the best kind. Think the numbers could be even better with shorter/bigger headers.
Great looking car and engine 68 Rat Rod! :)
Not to hijack your thread but just had IMM build a 414. Here’s the dyno sheet. Not bad.
