If I put the adjustment tab and bolt back in and put tension on the torsion bar will that put enough pressure on them to I can remove the nut on the pivot shaft in the lower control arm without the pivot shaft just spinning freely?I cannot catch a break with this front end rebuild. Still taking it apart. I am down to the lower control arms and of course they are not cooperating. One of the nuts on the strut rod will not break free.....It has this pin going through it I cannot remove which is a problem but not the biggest problem I have. The nut on the pivot shaft was coming out and about a 1/2 inch away from it coming off and now the pivot shaft is just spinning and the nut is stuck . I can see that the bushing is shot. How the hell do I get the nut completely off and also the torsion bar loose enough to slide it back out of the way?
