Any tips for removing broken rusty wheel studs from the hub?
I agree with previous post. They look like replacement studs, which were never swaged. A big hammer will probably work ok. If you want to be extra careful, you could support the other side with an appropriate sized socket.Those do not look swaged to me. Looks like you can drive them out with a BFH.
Your "press" is under the hub in your picture.
Spot welded on the back? That's a rotten trick to play. Sounds like something I might do.![]()
I concur. Whatever the circumstances call for. Within reason that is. That is a reasonable fix. Undoubtedly I would forget I had done such a thing and curse some poor un-named fellow, until i recalled doing it myself.One spun wheel stud on the cuda and I told Dad we gotta tack them on. Works great
. HAPPY FATHER'S DAY Y'ALL!If the new studs will not hold, rather than spot welding them why don't you put slightly larger studs in? There are probably a hundred different size studs out there. Maybe you can find one with larger diameter spline, or maybe even go to 1/2" NF thread. You may have to drill the hub and drum together, but you're only taking a little bit of material out. Just leave one or two old studs and nuts tightened, drill the other ones, then install new studs, tighten some nuts on the new studs to hold the hub and drum together, then remove the rest of the old studs and nuts and continue drilling out the remaining holes.WOW!
Thanks gents. I didn't expect such long list or replies. I'll try some heat, PB & a drift pin. That's in house and the first thought. Sadly, no press or cutting tourch, though maybe a the tiny hole saw.
Between both hubs, I would like to replace them all myself. Some are spot welded on the back. A few have threads that are just worn out. Then it engauges but is not just right.
This is the last hurdle.
