68 barracuda 340 dash
63savoy426
California
Can someone give me a ballpark on what a 340 dash from a 68 barracuda is worth? Its the entire thing.
Came witj a car i bought. Thanks
It also depends on if it has ralley gauges or regular gauges...
Entire dash with aged 68 only upper and lower pads, all the gauges in unknown condition, bezel in typical condition, all in one big box, 300.00. Condition of each piece matters. A OEM tachometer in the center pod and the 150 mph speedometer can make a small difference where condition is unknown. Restore or replace either speedometer or any piece is about the same. You might get a bit more by parting it out ( more effort in shipping several smaller boxes ) but... since that dash is one year only it will be a slower sell.
Everything in excellent condition, pulled and properly stored away many years ago,, speedometer shows 70K miles or less, plug and play ready, and the color a buyer is lookin for too, as much as 1600.00 Good luck with it.
yeah, good luck w/ that !
No such thing as a "340 Dash". All 68 Barracuda dashes are the same other than option specific differences.
A 340 car could have had a dash that was identical to a slant 6 dash.
Rally gauges. I just said 340 because there was a tag on it that said 68 340 barracuda. Thanks everyone
68 restored dash with a 69+ 150MPH speedo
Thats a 67 inst bezel (round radio holes)
Pic of the back of speedo will tell if its 67 as it would be threaded.
Also does metal dash frame have a vin attached?
68 and 9 would have a vin on it.
Looks to be non ac as well
So what exactly do i have here and whats the speedo worth
No vin
It also has a labelled fan switch so its not 67 either. Nor is there a hole for dash mounted ign' switch. The plastic column door and the ashtray are also 1 year only parts of the 68 dash. I don't see the bolt holes for the 68 lower dash pads either. I'm going to call this a 70/71 Demon rally dash.
No hazard switch either so its not 67-9 cuda. Yer right Ben with 70+
I did notice the very end of the dash cap appears to be cutaway for lower pad join, so that dash cap may be the only 68 model part pictured.
So after looking carefully there was a vin. This was from a 71 dart 2 door hardtop 340 car. Thanks everyone
Wasn't tooo long ago that a guy was here asking about that dash. He showed a sharp 340 Swinger. If my memory serves... it was built for charity auction, raffle, something like that, and someone decided to poke a standard dash in it instead of proper rally dash/restore. That's the type buyer you're looking for. Good luck
Any idea what its worth
Still 300.00 By the time its restored and bolted into the car, about a grand spent.
Sure you could get a hun or more for that speedometer before sundown. The rest of it might lay under foot a very long time. I aint so sure I would part it out. Like I said, the rightful car is out there.
What about the frame and harness
