intergalactica
- Joined
- Dec 16, 2006
- Messages
- 416
- Reaction score
- 30
Do lower control arm reinforcement plates (that have to be welded on) actually make a difference?
That’s the same thing I was thinking but the stock control arms appear to have a stout construction from the factory. Wouldn’t water collect up in there and ultimately cause some rust issues?I would think tying it together like that would make it more ridged for sure .
The reinforcing plates absolutely make a difference. Boxing the open end of the LCA adds quite a bit of stiffness, and the plates don't really add that much weight. The other thing is that the plates are very useful in keeping the ends of the LCA from spreading apart, which they can do over time. You can see that in @Jim Lusk 's youtube video on adding the plates
I go a step further when I do mine and add a strap right across the back of the LCA where the pivot is. Less flex=more predictable handling
You do have to pay attention to the location of the strap to make sure it doesn't interfere anywhere
That same strap application could have been used in place of the fancy aftermarket plates too. I imagine those plates capturing gravel and such.
they have to help,but how would you really know?would you have a seat of your pants feel? so to speak,could you feel it in the steering or suspension?
Well the straps will keep the ends from spreading apart, but they don't help the stiffness of the whole arm.
Even with the plates the LCA's are pretty much still open on both ends, and the holes are pretty substantial. I drive on gravel roads a decent amount and haven't really had any buildup. The plates are easy to make too if you don't want to pay for them, although for the price they get most places it's worth it for the time spent, especially if you bundle them in when you order all your other suspension rebuild parts so you're not paying shipping on just the plates.
you want seat of the pants results? Get some frame connectors. Bolt in or weld in (although I would tack the bolt ins too) that makes for a rigid ride and your door hinges will thank you.
How can they NOT help? Pretty cheap upgrade, too.
That video was made by Jim Lusk, if I am not mistaken. He is always gracious with sharing information.
Pretty sure that video was done by a FABO member.
I bought the plates from PST and put them on my LCA for the 69. I will eventually get them installed lol
Yer killin’ me! I put Jim’s name right in my post!!! It’s right there before I included the video! I even tagged him!
I love all of those parts except the subframe connectors. Those uscartool subframes are a colossal pain in the *** to weld in.
I’ve installed those and made my own tubular subframe connectors, and I’d need a whole lot of convincing to do the uscartool subframes again. The tubular subframe connectors work great too, and they’re much easier to install.
I plan on adding tabs of the same thickness down the side of them and plug weld through the floor, more like the original frames.
