roccodart440
- Joined
- Apr 19, 2010
- Messages
- 6,803
- Reaction score
- 3,580
I'm not sure if you can get one for the 8.75 but I love the tru-trac.
I will post since I'm literally in the middle of swapping my 8 3/4 for a Dana right now. Looking like I will end up with around $1400 in the Dana. Wish I would have took the advice to do it first.
Started with a craigslist truck Dana for $150. Got it torn down cleaned up and painted. Just pulled the 8 3/4 this weekend out of the Dart so I can haul both housing to Moser. This way they can shorten it to match what I had, weld the perches at same place and angle, weld on Mopar ends, build me custom axles. I am lucky to kind of close to Moser so I can let them do the measuring
From there I am buying the power lock sure grip from Dr Diff along with needed bearings, seals, ect. When all put back together will slap it in and measure for my new driveshaft with 1350 u joints. Luckily my truck Dana came with perfect looking 3.54 gears so I'll be reusing them.
Can't wait to get this done and get it back to the track to see how bad the change from 3.91 to 3.54 will hurt me. Slapping on a Procharger this spring so that is the reason for the Dana and gear ratio.
Okay, so I do know that Danas came on Fords, and my if looked into right the f-250s? At this point, I havent pulled the trigger on anything yet and well if anything, i will just store the rear end in the garage for a future project or even this project. Cause parts around here are only going to get more expensive or not able to find.
So my real option in my area is hitting up the local u-pic-part yard. Which i have no problem with. I just want to know what i am looking for when i go in there. So any pointers on that?
Some fords had Dana's some 9 inch. 80s and 90s ford and dodge 3/4 ton vans are good just make sure they have the 3 inch axle tubes. Some of the later model stuff has 3.5 inch tubes. Mine came out of a 96 ram 2500. Basically any Dodge 3/4 ton pickup from 73 to late 90s should have a Dana 60 in the rear.
Just watch craigslist for a dana 60. Last one I bought was $40, from a '74 F250. Guy just wanted it out of his garage and had no luck trying to get $100.
Someone post the weight of an 8 3/4 verses to weight of a Dana.
Pinion Comparison - Quality Body Shop Drivetrain
went back to an old post to find > Dana vs 8 3/4
both are 53" F-F , weighed without brakes
Dana- 4.10 spool/ stamped cover = 97 lbs.
8 3/4 - 4.56 spool= 99 lbs.
[QUOTE
And looking at your pics again, your 60 is a HD case right?
put danas in all my drag cars.
have either crushed the tubes @ the spring perch or bent housings on the 8 3/4
wanted the thicker tubes ( in the above dart) due to running a 540ci.
I think the CM at .250 would be strong enough. If I can find a pipe size that works, it'd be even stronger. Still shopping around.
I blew the ring gear caps off my 8 3/4. $1000+ down the tubes.
To the original question a Moser setup would be great for for a 500+hp dedicated track car, but a "budget Dana" is the ticket for a street/strip setup.
Hey wait a minute, that was a funny "down the tubes" ?
