jegs or summit , 1 qt. , return system or not, either way . plastic, colors, cheap, and works.Any suggestions for an inexpensive replacement overflow/reservoir tank? 66 Plymouth Barracuda?
Thank You
Awesome thank you very much. Looks like Summit is the winner. I like it.I installed a 2" x 10" overflow tank (summit was cheap and steel) between the horns and the radiator. I had to fab brackets but fit really nice and look somewhat factory
Too heavy, alum or plastic for me. Used too run a beer can on the hemi ! LOLJust a thought here.- if you are handy in the shop , how about converting a used torch/lantern propane bottle. I have not done it but seems like it would work.
Yote
So your proper fill level is a inch or so below full radiator. Is that air causing rust? Recovery tank prevents that embarrassing belch from a overfilled radiator and keeps the radiator completely filled.Why do you even need one? My radiator fluid stays at the same level all the time.
Yes fluid expands when hot. Here's my story....But when its hot shouldnt the coolant expand and fill up the extra inch?
actually just ordered this one..
3"X16" (3x16) Polished Stainless Steel Radiator Coolant Overflow Puke Tank 50OZ | eBay
supposed to have some sort of catch can to be legal in nhra .Why do you even need one? My radiator fluid stays at the same level all the time.
