a 6-53 is a big engine they weigh between 1800 and 2000 there no longer than a 440 but are very deep .
That and if you have a turbo pushing oil don't start it. LOL It will run till it uses all the crankcase oil.I had a inline 6-71 run away on me one time scary experience . WARNING . don't let anyone mess with the gov on a Detroit unless they know what they are doing ever .
Even the Iron block 4-53 is over 1100 lbs and still kinda talla 6-53 is a big engine they weigh between 1800 and 2000 there no longer than a 440 but are very deep .
A non-computerized Cummins 6bt is the way to go for a diesel pickup truck.
heres a runnaway melt down!
this thing is just super cool!!! another thing is thay can run backwards and burn oil doing it and blow exhaust out air intake!
A 6V-53 is only 318 cubic engines. I have worked on a lot of them in the Army. The 6V was used a lot in the old M113A2A3 APC . The M109 howitzers had 8V-92 in them etc. we allways used a clip board after a rack Adjustment, Incase of a run away.a 6-53 is a big engine they weigh between 1800 and 2000 there no longer than a 440 but are very deep .
Problem is that's about the going rate for one of those trucks. High mileage, body rotten off the frame, blown transmission, etc.. they still bring $2k and up.That would be fine if I could get one what I think is reasonable. Around here any cummins that the seller can convince himself "might run" is at least 3500 and in a truck 5K and up, running or not
gonna have 2 grand near abouts in a 453t as well, bell housing gonna be hardest thing to get!Problem is that's about the going rate for one of those trucks. High mileage, body rotten off the frame, blown transmission, etc.. they still bring $2k and up.
