Stop in for a cup of coffee
Do I just plug the other side then? This set up is different than the old Holleys I've got experience with
Not unless it has a fuel transfer tube from one bowl to the other...
The rear bowl will not get fuel if not...
If it's set up for dual feed, then you need a dual feed fuel line...
If it's set up for single feed, then it will have a transfer tube between the two bowls...
I only have the one side But it shows the list number
2 days in shop, cruze is washed and delivered. Came out less than he expected.
Just tires tomorrow,then maybe i can check my truck for the new exhaust leak.
Sometimes the service manuals are not updated...
Agree. Which was why I checked the Hamtramck Historical Library for TSBs - only thing close was the advice to reduce timing if it pings or try to ge the customer to buy higher grade fuel.
In a thread about 318 timing someone posted a snippet from '69 Plymouth FSM- so I was surprised that its different than the Dodge version. I assume the snippet from the Plymouth version is what he claimed, but there's always a little doubt. Discussing it here because its just would have been a total side track.
Show us a picture. Both sides.
This is just a random pic off the internet but notice on the fuel Bowl the inlet looking tube that angles down from the float adjustment screw? There's one on front and back on each side, one side of each is set up for the inlet but what stops it from leaking out the other side?
I’ve got Chris on ignore and I can still guess what he’s asking by the responses.
The duel feed Holley is set up so you can put the duel feed fuel manifold on either side depending on the application. The side you aren’t using gets threaded plugs to block them off. You buy the duel feed manifold that best suits your application and clearance.
Good move, Dave. No dueling around. ;)
I'm told no drooling either.
Some say its only goes downhill once it starts...
:lol:
