Dyno day! How much power?
doogievlg
Amelia, Ohio
Tomorrow the engine goes on the dyno so I figured we could guess some numbers.
360 .30 over
10:1 compression
Edelbrock heads slightly ported
Flat top pistons
Roller cam .522 intake duration is .235/249 at .50
Mopar adjustable rockers
Performer rpm intake
Holley 750 dp
Cookie cutter build so I’m sure a lot of you guys will be really close.
Goal of 400+ hp?
You got it IMO.
But I await......
420 or better HP.
I took a half day off work tomorrow to make the hour and a half drive up to the builder for this. Only big thing left to buy is the Frank Luppo converter.
Just tell the operator to keep adjusting things till it makes the power you want. Ta Da
Seriously should make 430ish HP
If everything goes right I'm saying
420-435 HP
370-385 TQ
Should peak at 6200-6400 and shift about 6800 depending on gearing and converter.
This?
