I think gate #7 is closest....Hoppy can I walk from the post hotel to the fairgrounds, or is it to far??
And your site it by gate 3??I think gate #7 is closest....
We are actually closest to gate 7, on row P P205-P206. Gate 7 is close to the right of me. Gate 1 is a ways to the left. Go on the Website and look at the map, listed under downloadables...And your site it by gate 3??
Thats what I am afraid of!!! I will work it out...NOT sleeping with Ray!You can always sleep in Hoppy's truck with him........
AKA passing out!!Actually the chairs I bought there last year are a good canidate for sleeping!
the full panels include the sides, tops up to the truck gutters (6 inches or so) and connects all the way up to the roof pillar as the factory mounted them, requiring a filler to close the gap.
Skins, they simply are the side portion, usually they'll mount at the front where the door opening is, but then, only mount along a stitch weld right were the top body line is, sometimes there'll be a 1/2 flange at the top to connect to the existing quarter panel, brand dependent. I went with skins simply because I didn't want to deal with lead body solder at the roof joint. plus the 300 dollar price difference.
sounds about ballpark but i dont have my notebook on handI've got a question on drive line angles. I have a slight vibration around 60-65 and disappears until around 90 or so. I checked my angles and my trans is at 0* and pinion is at -3*. Does that sound right to you all?
my wife has had the same one for 4 years now, no issues. Make sure you clean the thing.Well another Keurig machine bites the dust! Off to Kohles to return it, Again!
might seem stupid, but have you checked your U-joints for wear or play?Thanks, I forgot to measure the angle of my driveshaft just to see what that said.
Hey we must go to the same place.....Maybe you should try a different maker.
I just buy mine at a drive thru window.
I get mine with a cute smile everyday.
Dang....Groceries are gettin expensive.....Gotta run and get some groceries now. Be Back Later.......
yepDang....Groceries are gettin expensive.....
Depends on the force protection level. I know we're on Bravo level now, only active members assigned to the armory are allowed on the property. I don't know what their level is though.Well I finally looked at a map. Probably too far to walk from Carlisle Barracks to fairgrounds. I see Penn National Guard has a facility right next to the place. I'll see being retired National Guard if I can't park there.
