Stop in for a cup of coffee
Hoppy can I walk from the post hotel to the fairgrounds, or is it to far??
Barracuda window is off the truck. Spent an hour cleaning the butyl off the glass. It wont get me again!Another hour for a crate.
Made it big enough to handle all the loose glass. Total cost: $15.00
And your site it by gate 3??
We are actually closest to gate 7, on row P P205-P206. Gate 7 is close to the right of me. Gate 1 is a ways to the left. Go on the Website and look at the map, listed under downloadables...
Thanks Mitch and Ray for info, I am putting my plans for the trip together....
the full panels include the sides, tops up to the truck gutters (6 inches or so) and connects all the way up to the roof pillar as the factory mounted them, requiring a filler to close the gap.
Skins, they simply are the side portion, usually they'll mount at the front where the door opening is, but then, only mount along a stitch weld right were the top body line is, sometimes there'll be a 1/2 flange at the top to connect to the existing quarter panel, brand dependent. I went with skins simply because I didn't want to deal with lead body solder at the roof joint. plus the 300 dollar price difference.
Thanks for the explanation Chris!
I've got a question on drive line angles. I have a slight vibration around 60-65 and disappears until around 90 or so. I checked my angles and my trans is at 0* and pinion is at -3*. Does that sound right to you all?
sounds about ballpark but i dont have my notebook on hand
Moved transmission from shop to my small garage,where i keep parts that are ready to go.
I now know my lifting limit. A904 with no torque convertor. Thats as much as i want to lift. Im not pushing my limit.glass is safe and secure.
Well I finally looked at a map. Probably too far to walk from Carlisle Barracks to fairgrounds. I see Penn National Guard has a facility right next to the place. I'll see being retired National Guard if I can't park there.
Depends on the force protection level. I know we're on Bravo level now, only active members assigned to the armory are allowed on the property. I don't know what their level is though.
