fuel leaking from holley carb after shutdown
duster360
Alabama
What would cause fuel to leak from the carb down into the intake after the engine is shutoff?
Blown/leaking power valve. Wrong/bad gaskets.
Had this happen with 3 different carbs. The first one was a new vacuum secondary holley. Then I rebuilt and installed a holley DP. New one now is an AED DP. All three of them had this same issue.
hum, what am I missing here. too high, should be at the bottom
It has the large sight glasses. AED says that is where they prefer the fuel level. When they told me this, I was discussing things in general with them when I bought the carb, not about the issue I am having. May not be working for my application though. Maybe I should try the insulator and lower the level a little.
I have decided to go with one of these but not sure which. My intake is Edelbrock Airgap. Should I get the 4 hole and modify it into a dual plane or just get the single hole.
Open will be fine. U may have too much fuel pressure. Kim
I am currently using a Carter mechanical pump regulated to 6 1/2 psi I got from Mancini. I have also tried the 5 psi stock pump from the local parts store with the same results.
Isn't that just a metal shield ?
The spacer most use is of insulating material to help stop transfer of heat.
Black phenol, or wood has been used ,
Google it,
Yes,it’s a shield the keeps heat off the fuel bowls. They have been around since the 70s. They do help a lot. The thick gasket/spacer is prolly better. Kim
I run an open plate I made and added a shield up front to keep the heat from the upper radiator hose off the primary bowl. I also run a 1" 4 hole phenolic spacer.
