SS Lancer
How thick would a factory headgasket be for a 1969 340 ?
Factory would most likely be a steel shim gasket...probably ~ .020 thick....How thick would a factory headgasket be for a 1969 340 ?
Thank you SirFactory would most likely be a steel shim gasket...probably ~ .020 thick....
I never measured them but .020 sounds about right
Thank you Sir
Typo above... .054"The Felpro ones are .540. Make sure get the right thickness.
Thank you SirThe Felpro ones are .540. Make sure get the right thickness.
