boosted
Life Needs Air
I am looking into what are some good heads out there for the small block. I want something in aluminum and flows good out of the box..
Some racing in a prostreet car. 10.90 ultimate goal.Depends on what you are doing and what results you expect.
2400lbs with a 408. Prostreet with some racing. 14x32 tire backhalfed 904 transYou need to define the rest of the combo...street only..street/strip...strip only.....engine size...318...340....360...408....
transmission...rear end...slicks...going to take more then a set of heads to run 10.90...
how much does the car weight...
Trickflows should be out soon supposedly September. I think they will be better out of the box than the few that are available now.
Auto spell checked out on You, boosted... I second Trick Flow.
They do look good. I hear too much about the Edelbrocks not being plug and play.Those trick flows look nice, I looked at one at the Nats last weekend.
View attachment 1715212477 View attachment 1715212478 View attachment 1715212479 View attachment 1715212480
Ohhhhh....Those are NICE.....
Give me a min. to edit some pictures I took at the Nats.
May be so. Here's some ported x heads to compare. Different shape for sure.Is it me... ,or is the exhaust port raised, T.M.M....?
And those ,are how much ?Jeez, WTH are those tall heads? How about some W9s
with 408 in to get to 10.90's doesn't take much more than about 180 cc int port and [email protected], [email protected] ,275cfm by .500 lift... 11.1 compression blah blahSome racing in a prostreet car. 10.90 ultimate goal.
Chevy headsIs it me... ,or is the exhaust port raised, T.M.M....?
no holes for W2 exhaust?
raised ports?
did they relocate the stands?
longer valves/ taller springs standard?
what makes this head super special?
better chamber (does it then take special pistons)
changed valve angle?
valves moved
pushrod clearance- does it require W2 rockers and how do you make it really work if you don't?
