Exactly, We know it has a Voodoo cam. Intake looks like a Tarantula may be. The carb is a shop carb I bet. May be a 850? Shop headers as well. Love those dyno videos though.How stock is this engine? It has mods, but doesn't tell us what they are. Hughes can easily get more HP if you want. This is an unknown engine, no lessons learned here.
The cam peaks at 5400/4000 so probably at least several sizes bigger than stock, so probably the 704Voodoo @234/242/110+4, with some porting work; I'm guessing.What are your thoughts on this 340. Would a mildly modified 340 put out this kind of power?
That's what I like about you Cracked. You lay it on the line. Yep. it sounded good on the dyno and the numbers were good compared to the anemic numbers the factory posted back in the day.I wouldn't mind that mill in either of my A bodies. The 66 would be fun for sure.Probably a voodoo 268 and that combo is a 340-350hp max combo. Lots of happy numbers especially from a builder that used to be on this site.
Intake is an Air Gap.
Heads didn't look worked over at all from the quick shot. If they had some clean up porting, then 370 is possible. No chance with a factory X/J head is that thing making more than a true, track MPH observed 350hp. My 2 cents and worth less than you paid! LOL
I think I can change the limits for a different graph. No reason my example needs to top out at 9000 rpm. LOL It shows the flat torque curve though.The software produces similar happy numbers for the stock cam when the same options are selected. LOL.
Hp peaks early, so its calculating something isn't quite right in the sim.
