dartfreak75
Restore it, Dont part it!
I have a air grinder and dremel.When short on $$, I don't see why not.... filing is awfully slow.... borrow a small grinder maybe?
Just go slow. Spring comments tomorrow.I have a air grinder and dremel.
Yea it's rough its gotta come out I'm looking into diy honing. I'm thinking maybe trying some 600-1000 sand paper and polish it out I guess as much as I didnt want to I'm gonna go ahead and pull the crank and pistons. And go from there. Looks like it needs hot tanked there is alot of rust in the water jackets. I used a reloading caliper to measure I'm gonna measure again tomorrow and double check with a straight edge. Like I said I was fighting mosquitoes and was in a hurry lol. I will try and get the head cced in the next day or two. I'm really concerned about the block now. I'm kinda at a point where it may be better financially to just start the 360 build. If I have to do machine work on this block I might as well do it on the 360.If want to try to save it, wipe those out 100%, wipe some ATF in there and move up and down, and then repeat over and over, continuously wiping. You need to get all the crap out, even down by the rings as much as you can. It'll wear on the walls in a hurry; iron oxide is an abrasive material.
If the deck height is right, that is mighty good. What measuring device did you use? I thought this was not a Magnum?? No stock aftermarket replacement pistons that I am aware of are that high up. It WOULD be nice!
Agree with Mike seen it too many times cam duration one or two sizes too big for the application/ current buildOr higher actual compression ratio..... Was that a later production 340, like a late '72 or a '73?
They drew lines on the drawings of the cam profile to locate where the ramp changes.I gotta root around Wyrm's info on how the factory actually measured 'advertised'....IIRC it was at .008" lift??
Condensation.I'm not sure how this happened because the engine has been inside covered in a tarp for the last seven years before that it was driven daily.
Yea that's what I was thinking also. I also think it may have been more my fault also. More on that later.Condensation.
Air carries moisture. Warm air can carry more than cold. On cool nights the temperature of the engine metal dropped below the dew point of the air inside. Tarp doesn't protect against that.
However its an important principle to keep in mind: The amount of moisture held in air is dependent on pressure and temperature. That applies to fuel as well as water and so applies to wet intake manifolds when they go from low pressure to high. Just tuck that away for now.
That's what I'm trying to avoid. Lol no $$$$ for machine work.Bore it!
Then don't do anything. If you can't do it right, don't do it at all. You will just regret it.That's what I'm trying to avoid. Lol no $$$$ for machine work.
So you dont think honing will clean either one of them??Then don't do anything. If you can't do it right, don't do it at all. You will just regret it.
Nope!So you dont think honing will clean either one of them??
Rust and corrosion is not good. Ridge isn't as big of a issue as taper is. I have never wasted time with a hone where a boring bar is needed. I know it costs $$$ but if you are going to half *** it you might as well find a junkyard motor and roll the dice.So you dont think honing will clean either one of them??
Wow your in quite a mood today!! LolRust and corrosion is not good. Ridge isn't as big of a issue as taper is. I have never wasted time with a hone where a boring bar is needed. I know it costs $$$ but if you are going to half *** it you might as well find a junkyard motor and roll the dice.
I'm getting somewhere between. 062-.067.if you could get a good deck hight reading on that 318 and when you pull a piston a good comprission hight,..that would be great!! DWB
I think you need to spend your money on paint for your engine bay......lolYou should spend your money on some lower gearing
Build the car then build the powerplant.Ask and you shall receive I have a thread in the members restoration section please check it out if you want. I started with 1000$ I started with the safety stuff new brakes new bushings ball joints steering gear basically everything suspension steering and brakes is new! Iv got new wheels and tires (not installed yet obviously) new leaf springs etc. Well that took more than I expected so ran into problems indidnt expect I had to replace my lcas and torsion bars. Anyways long story. I'm now about 1500 in.
Meaning??? It dont have a dish. It does have a crown I thought all pistons had that.That .067, on flat-tops would be pushing 13cc then, and over .100 Quench. But that little dish on the crown is gonna throw several more cc's at the Total volume.
