nm9stheham
OK, I get 7.72 with the 360 heads, flat tops, the deck height, and .051 compressed gasket.... seems like math is still working the same tonight as always.
From Idaho.................Idaho!
Find a thinner head gasket, and shrink the chamber volume
Oh yeah. I gotta remember........think taters.
We are going from a .065" thick gasket to .040" thick....
Tater salad...
273 heads it is?
308s are the open chamber swirl port roller cam 360 heads '88-'92.You may want to find a pair of 302/308 heads from an 80's 318. Mill 'em down. They have smaller swirl combustion chambers.
I'd rather build it right the first time.
I don't accomplish anything if I half-assed slap it together and plan to do it again later... I will then have that left on my "to-do" list. :violent1:
I want to cross it off and not feel like I'm trying to kick water up hill... :banghead:
You are so lucky , best we get is 94 octane 1.30 -1.45 a litre or 5- 6 a gallon . I can buy race fuel in 5 gallon jugs for 12 a gallon . 11.3 compression , sure would like 100 octane all the timeI would just get it running with the 273 heads.
To fix the compression right would require pistons and most likely balancing the bottom end.
Who knows what fuel will be available in 10 years?
I am lucky here in WV, with so many stock car tracks you can buy 100 octane at the local truck stop for $4.00 a gallon.
...We will be picking the cam later after we figure out which heads we are going to use. I do have some "mild" street cams that may be ok. I don't want anything too big if I don't have enough compression to back it up.... I'm thinking around 268° duration range.
Then I have to mock it up and check the piston to valve clearance....
Then assemble the engine and drop it in... :burnout:
I had to reread this because I knew you mentioned a goal of not buying anything...what all cams do you have available? Maybe something similar to a comp high energy? Now knowing you're not likely to get your SCR goal, I agree with the above statement though.
My pop and i restored a 79 lil red express. Working w the machine shop in my dads area we decided to put flattop pistons to make up the difference for the open chambered 360 heads and factory low compression pistons it had, we also put in a 68 340 cam. Truck ran great. Dont recall what the compression ended up at, but the ***** would ping on anything less than 92 octane, and ran like a scalded dog.
Flat tops zero decked with 65cc heads and a .038 head gasket. Just shy of 11-1.I am rounding up the pieces now to do a 360 build after abandoning the idea of a big valve 318. With 65cc chambers, i have to use a slight dished piston and thicker head gasket to get compression down to 10.22 to 1. Otherwise i am looking at over 11.5 to 1 with non dished flattops. Not a streetable combo at all.
