72 duster 360 NA to 390 Turbo
No muffler, not loud at all. Get a little exhaust smell inside. Yes GT45 and I was nervous about the issues with the truck turbo so I drilled the restrictior out bigger. No issues so far. Put about 30 miles on yesterday. Working on the carb tuning..
I was hoping Santa would have left me a Holley Super Sniper 1200, bit I guess I was on the naughty list. :steering:
Yes the dominator is a nice piece, and pricey. Holley makes quality stuff. I may try a FITech like I have on the turbo truck build. That way I won’t have to swap intakes but I do have a port injection intake if I decide to go that route.
There are places like Monkey fab, CX racing and others that offer t4 merges that are already made. I just used a T4 flange and my vise and ovaled the pipes to fit in the hole. Maybe 1 hour tops work time. Lots of YouTube videos on how to do this.
If you are going that route then I would go with the Holley Sniper. Too many guys are having trouble with FI Tech.
Update: I fabbed up some wastegate dump pipes last night. The flanges came with the wastegates. Used some stainless sink drain line from a lab. Works well and was cheap at $1.80 from the recyclers.
Pics for motivation or a good laugh. Thanks to my cousin for the final weld. Should have tig welded for a nicer look but I don’t care and you barely see it. Just looking for function and it will do that! Trying to get it to Rockingham on the 20th for the Mopar show. If not this then the turbo Truck is going. Either way I will keep those that are interested informed.
Cool project......but I have to ask, did I see you said you machined the valve seats .080" DEEPER? Man, no way would I have done all that. The valve seat area is one of the thinnest places in the head. Has water right under them. Maybe the Magnum stuff is thicker there, I don't know. Good luck with it! It sounds strong!
I misspoke there, it was the spring seat, sorry for the confusion. I called Hughes and they said I could go 120 thousandths before I hit water.
