4 Speed console brackets
Joey4speed
Coastal NC
I ordered the console brackets for my 69 GTS, since it originally had a 4 speed console with the N-85 Tach. I'm not exactly sure where the 3 brackets go (see pic from AMD). I did see the automatic trans schematic on FABO but the 4 speed looks different. American Metal Direct has NO idea either.
Can anybody shed some light on this?
Thanks
Console Brackets | AMD 490-1067-MS
The 4-speed console parts shown are the front bracket, the end bracket, and the seat stop. You can see the seat stop right next to the shifter. Here is a picture...
The front & rear console brackets are the same for 4-speed & auto. They're also located in the identical location...
Makes sense. Wonder if its needed for bucket seats.
It's only needed on a bench seat to keep it from moving too far forward & interfering with your shifting. You can leave that bracket off with bucket seats. You can see the seat stop bracket a bit better in this pic.
Either buckets and console or bench with no console. You can't put the console and a bench seat in the same floor. So the console brackets are just 2 pieces. No bench seat stop req'd.
That 3rd little piece that the aftermarket included... I'm almost certain its a tying brace for the added floor hump section. Sort of like the 4 added plates at bucket foot prints, Just a little something more to prevent sheet metal flexing. Someone with a OEM 4 speed floor could confirm.
Check the picture of my 69 GTS 383 4-speed console car above. It always had that "bench seat stop" welded on the floor. I also have a few bench seat 4-speed cars currently and they have the same bracket.
On the assembly line, the bench seat stop probably went in every 4 speed floor. Console brackets and bucket floor plates went in later.
I don't believe the flat piece of strap metal that aftermarket included with console brackets is meant to be the bench seat stop. It has a predrilled hole in it so maybe the carpeted side cover attached to it.
I don't know why that hole is in there, unless some of them had it...
