Suspension kit arrived today.
Frodee
Off center a bit
NORTH DAKOTA
received my complete front suspension kit from QA1 today and ordered it on Saturday and here in less than a week. bolted some of it together to check fit and so far so good. I'm a happy camper.
Putting the spindles on and found that the upper control arm ball joint is smaller in size. Will the larger ball joints screw into the QA1 upper A arms?
Never mind I found the answer I'll call QA1 on Monday.
QA1 has both small ball joint and large ball joint UCA’s. The ball joints are not interchangeable, so if you wanted large ball joints you have the wrong UCA’s
Found that out was told by tech line the only difference was the motor mounts. Not blaming them just not knowing on my part.
The only difference in the K frame from 68-72 and 73+ is the motor mounts. UCA’s are a whole different ball game.
I'm learning should of ask you guys before I ordered. Next time I order something I will ask.
Would be nice if the tech. guy would check in once in awhile and answer my questions. But maybe I'm on the wrong page for asking questions.
Nah you’re in the right place. It is the weekend though...
The difference in ball joints/ UCAs is whether you are gonna use Mopar 73/ later factory disk brake spindles..............
A arms arrived and sitting on all 4 again. Everything bolted together just fine just have to hook up the sway bar to the lower control arms. I am happy.....
