Lca bushing help.
Buy my delrins and forget the rest.
-Needs no outer shell
-Leave inner shell on the pin
-Quiet due to its durometer
-Lasts forever
-Stiffest bushing available
-Torque in any position.
-Lasts forever
Wish I would have had this info before I removed my sleeves from my pins.
JMO. If you are going poly you need to have nice clean shells. If not install new clean ones. I choose to use factory style rubber and prefer to install the new rubber unit on the pin first then into the A-arm next. It is easier than trying to support the unit when pressing the pin. Just an opinion!
-Lasts forever
Do you have those for upper and lower? How much?
I ordered the PST polygraphite rebuild kit last year. After reading a number of posts recently, I decided to order the greaseable pivot shaft kit. I just received it, and I am very impressed with the quality. The pins actually have Proforged stamped on them. The bushings are a light press fit onto the pins. I tried to press the bushings in the new shells, and I could only get them started with hand pressure. The pins are not stepped down, so no inner sleeve is necessary.
