I made a video posting my results. Hope it helps somebody.....
actually, they ride smoother. I was surprised. Nice improvement. I need to re-adjust the traction bars now. When I brake torque, the drivers side lifts more aggressively than the passenger side. Used to lift evenly.Well of course they do cause they aint just shocks. Can you tell a difference in ride quality at all?
Looks great I'm gonna have to get me some of those my dart has a really bad sag to the rear end I put on new leafs and it didn't help it any so I put on shackles it helped but now i know all the negatives of shackles I dont want to run them so I will try them and see if it helps . Thanks for the video
I have some pictures. I have checked the frame rails everything looks ok to me. I dont think it's anything wrong with it I think they just sit lower than my liking. I see it on alot of them most of the a body hardtops I have seen that I like the way they set have ss springs which is something I'm gonna do eventually.You should be really looking closely at the rear of that car. Frame rails, all that. Something doesn't sound right there.
Between 1/2 to 3/4 inch above the tire.So what was height difference after you went for a ride, from where you started?
now all you need is worn out front shocks and /6 T bars.actually, they ride smoother. I was surprised. Nice improvement. I need to re-adjust the traction bars now. When I brake torque, the drivers side lifts more aggressively than the passenger side. Used to lift evenly.
lip is rolled up..… has a b-body rear end.... I like a little bit of a deep dish wheel, don't like new frisbee rims on a old school car… LOLWhy not get a different offset rear tire, roll the lip of the fenderwell to get it in there. Dusters have pretty big rear wheel houses.
just a normal shock OE type shock... there wasn't a name on them.What shocks did you have before the swap?
A bit extreme kinda like the donk mobiles
Like I said. lolnow all you need is worn out front shocks and /6 T bars.
