Flood carNew Mexico car. Every time I take ANYTHING off this car, one acre of New Mexico falls out/off . When I pulled the speaker out of the dash, it had about 1.5 inches of red sandy clay in it.
I’ve got a nice set if you’re looking to replace them.No AC at this time. The current 318 came out of a wrecking yard. It has a mishmash of 273 and 318 stuff, the throttle linkage was modded for a 2bbl, and the kickdown linkage from the 904 simply vanished.
Wife wants AC at some time in the future, so the pulleys will go on the “new” 318. Thanks for the info.
That sounds right. The newer compressors don't have the same design so I bet a new one would would be OK with a solid drive pulley. And I'd have to wonder if that rubber is reliable anymore.Yep, that a/c pulley is a vibration damper in design. I don't know if the compumper operation resonated through the car or the damper just absorbed some drive belt bounce.
