EFI!Sooo Question for the brain trust that is the coffee shop....
My 408, coming soon, in my 66 Dart, Carb.d or EFI? What do you guys think ?
nah, if anything, more fun. the Holley system is a data logger too. you'll be constantly tuning and driving until you find the best tune for your combo. To me, thats more fun than swapping jets and idle cams.Won't make the car boring to drive?
Dart already has a return line and a good pump. Malory pump....I would go carb just to keep costs down and make it simple. Easier starting would be a plus but you can help that issue with a carb by using a small electric pump and a fuel return filter.
Sounds like you're set for a carb then.Dart already has a return line and a good pump. Malory pump....
500.00 for HP Holley Carb, 1700.00 for EFI. With intake....or so.....I would go carb just to keep costs down and make it simple. Easier starting would be a plus but you can help that issue with a carb by using a small electric pump and a fuel return filter.
The tuning and drivability would be a lot of fun. Fire it up and go. If boring, the just leave other things that you can work on all the time....at least it runs. I would love to change my dual 660's on the tunnel ram to dual Fitech!!
The Hemi Ram is not boring to drive.Won't make the car boring to drive?
Edelbrock AVS2 800 Edelbrock.com: Edelbrock AVS2 Carburetors - The Future of Carburetion500.00 for HP Holley Carb, 1700.00 for EFI. With intake....
~800 for the FiTech500.00 for HP Holley Carb, 1700.00 for EFI. With intake....or so.....
My brothers Hellcat sure was boring to drive! Really!!! So boring he got a Demon to replace it with....Ho hum,....Like a sewing machine.....I am not kidding...The Hemi Ram is not boring to drive.![]()
I paid 1k for a refurbished sniper master kit from holley.~800 for the FiTech
Like that....Thanks Mike...
Whatever floats your boat Tim.Sooo Question for the brain trust that is the coffee shop....
And dang reasonable price as well......
I am in the simple dept. as well......Whatever floats your boat Tim.
@Rainy Day Auto and myself are into simple. If I wanted EFI I'd buy a new car - something made in the last 20 years.
But you are you. Do what you enjoy.
EFI is better when you want to pass strict emissions and still have some torque and power. Its much easier to play games and do things the timing and mixes that are unnatural.
Otherwise, its a wash in terms of performance and efficiency.
Keep in mind this is the same company that sells carbs with the wrong booster length.Like that....Thanks Mike...
Cut the S**t out of my arms, getting this Master Cly installed, way up under the cowl on this Escort. I charge extra if I Bleed....![]()
And a breeze to tune with springs and metering rods. Rarely do you need a jet change if the carb is sized right from the start.And dang reasonable price as well......
Beauty of a carb is that it supplies in direct response to the engine demand.I am in the simple dept. as well......
I am in the K.I.S.S. camp.Beauty of a carb is that it supplies in direct response to the engine demand.
Especially once on the main circuits, fueling response from the boosters is instant.
But for some, punching numbers into a screen is simpler.
