gzig5
Will a BBM roller lifter work in a SBM and if not, why? Diameter is the same at .904". I know the pushrod seat height can be different but would custom pushrods correct that? I think the roller diameter is .800". Guy at work thinks his dad has a used set he would let go cheap and if they can be made to work I would love to run a solid roller. I'm not afraid to grind on the block or come up with some sort of custom guide or link-bar setup if off the shelf parts won't work.
