Rapid Robert
1/3 mile high banked rough dirt track. 63 dart 360/904/7&1/4 drum brakes manual steering P205/R70/15 street M&S tires. caster camber toe. thank you very much for your time/input
Any pictures??!!...1/3 mile high banked rough dirt track. 63 dart 360/904/7&1/4 drum brakes manual steering P205/R70/15 street M&S tires. caster camber toe. thank you very much for your time/input
Patience brother! EDIT I have /6 & v8 torsion bars, which should go on which side? and I have an aftermarket (stiffer) trans mount but I read something about if there ain't enough "give" in the (2) eng (1) trans mount that it could crack the trans case. the OE mt is 55 years old. what should I do/use?Pics also required for this type of post![]()
Good info, thank youIs the 63 same as 65 as far as torsion bars? I use a 1.12" on the RF and a .99" on the LF. I would use the biggest one you have on the RF and maybe one size smaller on LF. If you don't have at least a 1" or bigger for RF i would put a new Lower control arm rubber bump stop in there because it will ride on it especially on a rough track. remove the upper bumpers both sides.
yes sirThis must be a street stock type deal?
