Was 65 deg here today....Gunner got a bath outside......Little cool tho, he is shivering.......BAd weather coming then, time for a drink.
![:lol: :lol: :lol:](/mopar/styles/default/xenforo/smilies/smiley-face-laughing.gif)
Is he a inside dog?Was 65 deg here today....Gunner got a bath outside......Little cool tho, he is shivering.......![]()
Yes......Is he a inside dog?
Looks just right to me!
Cheers to that!Looks just right to me!
NoChris that thing back fire trying to start?
I wish you were closer Chris. I'd like to take a stab at that Poly and see what it's doing.
I have a feeling it’s something to do with that flapper. It’s rusted completely closed. Went to cut it out this morning and noticed my oxygen was empty. The gas place in town is closed due to the virus. Tried an air chisel to no availI wish you were closer Chris. I'd like to take a stab at that Poly and see what it's doing.
Flapper wont cause fast idle. It will be sluggish and maybe overheat.I have a feeling it’s something to do with that flapper. It’s rusted completely closed. Went to cut it out this morning and noticed my oxygen was empty. The gas place in town is closed due to the virus. Tried an air chisel to no avail
YepFlapper wont cause fast idle. It will be sluggish and maybe overheat.
did you check the back ventureies like I asked? Block them with our hand while running. Is there any vacuum there?
It's sucking fuel and getting air somewhere. Pretty steady it sounds like. I would say carb bleeding over but that issue usually doesn't cause a steady raise in rpm. Carb related I would bet. Timing will raise rpm a bit but if it get's too far advanced or retarded it will run like ****.did you check the back ventureies like I asked? Block them with our hand while running. Is there any vacuum there?
Damn, that didn't last long (enough) It was good.
I didn’t fire up today. Worked on plumbing the new gas tank and lines and tried to unfreeze that flapper. I will try it the next time I fire it up, possibly tomorrowdid you check the back ventureies like I asked? Block them with our hand while running. Is there any vacuum there?
Could be the choke fast idle is stuck......You DO have the 12 volt on the choke hooked up. right? Bet not. Connect that to the hot wire.....Bet we found the fast idle issue...It's sucking fuel and getting air somewhere. Pretty steady it sounds like. I would say carb bleeding over but that issue usually doesn't cause a steady raise in rpm. Carb related I would bet. Timing will raise rpm a bit but if it get's too far advanced or retarded it will run like ****.
Uhhhhh....Pizza here.....Chili, it's what's for dinner.
Chilly, it’s what’s for outside....Was looking at brown lawn this morning...View attachment 1715499148
Yes, it’s hooked up and to the batteryCould be the choke fast idle is stuck......You DO have the 12 volt on the choke hooked up. right? Bet not. Connect that to the hot wire.....Bet we found the fast idle issue...
I would reference mark the choke cap and adjust it 2 or 3 points lean-er. All it does is open choke sooner.Yes, it’s hooked up and to the battery
