Single to dual reservoir conversion
Tad
Not here
Finally getting to installing my brake conversion to a dual master cylinder. I figured out the distribution block passages. Can someone tell me which of these two ports goes to the front and which to the back? 1 and 2.
Would probably be a lot easier to tell if the lid wasn't on.
#2 goes to the front
jazak5 is correct, the rear goes to the front brakes, the front goes to the rear .
Not all master cylinders are set up that way.
Still drum all around!
And that would have been useful information. When you say you did a brake conversion, it’s normally a safe assumption that you installed disks. In which case the larger reservoir goes to the front brakes regardless.
Thank you. I changed the title.
