Stop in for a cup of coffee
d807879a-e2ce-4b95-b936-39c26fe7200d-jpeg.1715501145
It actually is not as bad as it looks........All that is to keep it from coming off the ball, it is a pintel hook hitch...
The hood is a difficult thing to manage, with only 2 handses. Fixed up the cracks,welded in extra support. Discovered i caused it to be a little shorter due to pulling arc too much.
Pull it off and flatten it some. Nope. I was standing on it and it wouldnt budge. Fixed it too good. 2 pieces of 3/4” square tubing and its way better. had to cut, and re-weld the T to get it a little flatter.
Buddy’s daughte’s car. Broken wheel studs. So im fixing. Hes my parts guy and i cant say no.
Front wheel hub and bearing on an 06 Express Van. Also rear rotors and brakes....Done in 2 hrs....Come and get it......:thumbsup:
Honda just got added to the cars that suck list. Its not even that old. Everything is stuck/seized.
Honda done. Finally. Did job on the floor, under the hoist. No fun.
First they promised flying cars, then 20 years later they promised flying campers...
