Please help this idiot
69CudaFormulaS
Active Member
Atlanta, GA
Please help this idiot identify the bushing that goes under this washer
for a 69 Barracuda. Been looking all over for diagrams etc so I can order replacements.
I might have some of those laying around, I'll look for you in a bit when I get back home.
Replacing the same thing currently on my 65 Dart. Just be aware that you need to remove the lower control arm to get the rear bushing out. At least that’s what I’m finding.
You're here askin questions, so that makes you not an idiot.
That's right, smart for askin beforehand.
I've installed the late and early struts on '68 suspension. poly 2 pc....then back to rubber 1 pc. Quieter crossing terrain height changes . Basically less shock resonance.
I like the rubber struts and poly upper/lower arm bushings. I like poly shackles and rubber fronts. Quieter with rubber front eyes.
I have some of the one piece bushings if you want them. I bought them decided to go with the moog because it included new hardware
