beanhead
Hey did you ever get oil up to the rockers, by turning the crankshaft while priming? If the shop left that plug out I'd be real tempted to slide the cam out to check bearing oil hole alignment...
Yes exactly like a freeze plug and installs the same way
I’m waiting for the RTV to cure before I try priming again. I did confirm the oil hole alignment prior to installing the cam, all looked good.Hey did you ever get oil up to the rockers, by turning the crankshaft while priming? If the shop left that plug out I'd be real tempted to slide the cam out to check bearing oil hole alignment...
You see those horizontal "tubes" going off to the oil filter? and you see the vertical one that they intersect? In the space on the vertical, and between the two horizontals; is where the cup plug goes.
If the plug gets left out, the oil doesn't get filtered.
If a second plug is installed, it will very nearly block the passage. It will probably read normal at idle, but as the revs increase there will be insufficient oil delivery.
As the contractor, foreman, and lead hand , of the project, it is on you to make sure it gets assembled right. Unless your father assembled it, trust no one; especially not your machine shop cuz they already IMO, screwed up by not replacing the plug that they took out.
BTW, when you prime it and try to get oil the the rockers, you need to turn the crank and stop, and then prime for many 20-30 seconds. It takes a while for oil to get to the rockers and fill the rocker shaft. If no joy, then turn the crank 15* at most and stop, then prime it again for 20-30 seconds. It can take a while to find the 2 spots that oil the rockers.
We've all made mistakes. Some of us have even started the engine with the ratchet still hanging on the crank socket..I'm not trying to defend the machine shop, but in his defense, all I asked him to do was remove the cam/bearings, replace the bearings, hone the cylinders, and give it a hot bath. I didn't ask him to remove any of the plugs as I had planned on replacing them myself. So, when I went to replace the plugs, I did so one by one. That's how I missed the rear cam plug.
That's what I was doing, but then again I got distracted by the damn oil leaking from the back of the block. I'll give it another go. I think I can reach far enough to engage the drill motor and turn the crank at the same time.
I'll call your ratchet and raise you a "reverse at highway speed"We've all made mistakes. Some of us have even started the engine with the ratchet still hanging on the crank socket..
On a small block:
Turn the motor to 90* before top dead center coming up on #1 compression. The pass. side rockers should get oil.
Turn the motor to 20* after top dead center just past #6 compression. The drivers side rockers should get oil.
I copied it off Hughes website a few years ago and saved it.....
Normally thoses two small plugs that come in the kit are for the oil galleries behind the cam retaining plate aren't they.View attachment 1715526294
Hang on a sec; you see that bag of pipe plugs? Any chance they also are "extras",lol? You know that at least a couple of them belongs inside the engine, right?
And missing them will cause catastrophic engine failure.
And don't forget the tiny cup plug that goes up into the galley from the bottom of the engine to seperate the oil into two paths; the first is to the filter and the second takes filtered oil into the rest of the system. If not there, your oil will not get filtered. I can just barely see the cup plug in the bag..........
And there is another plug in the cavity behind the oil filter, don't forget that one,lol.
I have to ask you every time because I cannot remember. LOL
You need some sleep. Your typing is gibberish.ou know that using rhe turn and orimw repear merhod yoy have to go around twice
at least the lifters should bleed down if someone precharged them with oil
better even than bent valves and pushrods
I didnt remember that
figured it out a long time ago and then forgot
I'll wirte it down and forget where
This is missing the point. If you turn the crank while priming, you will not ever see the oil to the rockers. In a non-running setup, it takes that 20-30 seconds to see the oil when the crank is stopped in the right location(s). Stopping the crank in fixed spots is not for convenience; it is to have any chance of seeing the oil coming out of the rockers.I think I can reach far enough to engage the drill motor and turn the crank at the same time.
On a small block:
70aarcuda has given you the shortcut in post #34. If the cam it drilled with the correct indexing, then this will save you time in finding the right spots. In a very few cases, however, the cam's oiling holes are indexed incorrectly. So then you turn 15* at a time and prime....and keep doing it over and over.
Here's a photo. Note the oil holes. When the holes like up with the oil holes in the cam bearings, oil travels through. The only time you can get oil to the top while priming is if you can find the spot where the holes line up or when you spin past them it will spurt oil to the heads. That's what it does when it's running. In a perfect world, the cam companies would groove the bearing surface for a constant flow. Maybe that would put too much oil up top. Those Chrysler engineers were pretty smart.Thanks, hope it didn't seem like I was ignoring the advice. Sometimes I need to be slapped with an idea a few times before it sinks through my thick skull.
Not that I can see. If they did the work you mentioned they shouldn't have removed any plugs. Like others have mentioned, after any machine work (no matter how good they cleaned it) clean it again. I use gun cleaning brushes, brake clean and compressed air to make sure all the oil passages were clean.Thanks TMM, the visual helps me understand.
Now I don't want to beat a dead horse regarding the plugs, but is there any reason a shop would remove those to get the camshaft and cam bearings out? I'm just thinking that they're still there. The only plugs I used from the kit were the plugs I removed (aside from the cam plug, which is now installed). Does that make sense?
