if you are in phoenix area you are welcome to come help me with my 65 barracuda gasser projectRunning out of projects. That's no bueno...
What part of Phoenix are you located?if you are in phoenix area you are welcome to come help me with my 65 barracuda gasser project
Be careful. I clicked on his location and a map with 7 mental health clinics came upWhere is Valle Del Sol?
Be careful. I clicked on his location and a map with 7 mental health clinics came up![]()
Valley of the SunWhere is Valle Del Sol?
A few of us never quit going to 67th and Bell LOL but it is officially back up and running. Pavilions not sure?I saw that 67th and Bell was going last Saturday. Does anyone know if the Pavilions has opened back up?
It’s looking this weekend will be the last with decent temps until September.
I would go to 67th and Bell but, I have the front of the car taken apart. I am trying to get the remainder of the body work finished.A few of us never quit going to 67th and Bell LOL but it is officially back up and running. Pavilions not sure?
Had an overflow of cars at Mixteca last night, must be the only show in town.
I am not very good, but I am willing to try. Or do you just want to use my mig welder? PM mePawned: i need some welding done on my 65 barracuda gasser project
Do you want to use my mig welder. I will bring it over. but if it is a larger job, I do not think this will do the job. I am not a good welder. I can tack things in place but beyond that I am not your guyi do need things welded on my 65 barracuda gasser project
i need subframe connectors welded in, floor pans alsoDo you want to use my mig welder. I will bring it over. but if it is a larger job, I do not think this will do the job. I am not a good welder. I can tack things in place but beyond that I am not your guy
I could probably tack in the floor pans.i need subframe connectors welded in, floor pans also
Going on my limited knowledge, I would guess that a stick welder would be your best choice for the final welds.
They seem to lay down a larger more substantial weld bead than the skinny wire of that my MIG welder uses.
The only welder I have ever used is my MIG welder.
