Magnum head porting for the beginner
'63GT
CA
Recently, in one of my fits of boredom, I grabbed a spare test head.
A '97 Magnum off of a 5.9 with 1.92/1.62 valves. As I went through my normal process of grinding and testing, I discovered how this head responds to changes. I enjoy this sort of thing. Quirky.
I had fun with it. 255 cfm worth of fun with a stock 1.92 valve. It will go more but, not without a lot of nit-picking. I wasn't up to that this time around. Wasn't bored enough, I guess.
So my thought at this point was, with the growing migration to the Magnum series iron, why not do a How-To for the low buck – can't afford a port job – DIY sort of guy???
A guide to 30 cfm extra flow that even a newbie can replicate in the corner of their garage.
A fail-safe approach that won't turn your head into scrap. Complete with flowtests, so that you will have a good idea where you're at.
Again, this is for the newbie ! While I'm sure I'll draw the criticism of some of the other porters on FABO, this is not for them. But, help is always appreciated :)
With that, HERE WE GO !!
lt wouldn't be right to make a baseline test without touching up the Valve Job. Intake was short work, re-establish the seat and locate it with a top and bottom without upsetting the OE VJ.
The exhaust is going to take some effort. See how the Exh seat grows in width as it gets closer to the Int?
For basic info, let's CC it, as cast, shall we?
Any guesses ? 154.8 cc
Now comes the flow test.
I will be using this Radius Entry throughout the testing for consistency and to reduce any variables.
The radii I used here is capable of supplying 320 cfm without any restriction. Plenty for this head...
I will also be flowing every .050, it makes it easier to make an assessment.
OEM 1.920 valve. I added a 28° BC .050 wide: (easy to add)
.050 46.3 47.8
.100 75.8 80.3
.150 106.2 113.4
.200 132.5 141.4
.250 156.9 165.2
.300 179.7 186.4
.350 196.4 202.6
.400 206.4 213.1
.450 210.3 216.8
.500 211.2 218.0
.550 213.0 213.8
.600 212.6 210.3
Now lets measure the bowl ID and see what we get. The Superflow manual states it likes to see the bowl 80% of the valve diameter.
While this is a decent percentage to work with, I feel this is merely an entry level objective and should be limited to low lift applications.
While this head started it's life in this realm, we want to raise the bar. In fact, my testing over the years have shown percentages up to 85% does not limit low lift efficiency, that much, but does aid in lifts above .500 while 80% does not. 85% is our target.
Pushing the percentage to 88% is not uncommon for race applications, and a 50° seat is frequently used.
The 50 ° seat does hurt the bottom end but, when using cams that are >275° @ .050, so what.
The smallest cross sectional area (CSA) is about 1/2” below the seat and intersects with the port cast at the bottom of the counter bore. I get 1.564” here, that's 81.4% of the 1.92 valve. Way to go!
That is much better than some of the stuff turned out in the early years but, we'd like to be about 85% for this project. 85% of a 1.920 valve is 1.632. Well ! Thats just a hair over the exhaust valve diameter ! So lets do this, take your 1.620 exhaust valve and stick it in the intake port and scribe a mark, like this:
Your scribe mark should be visible like you see here. Yellow arrow.
We are going to grind up to this mark. Use the Exh valve as a template. Take your time, it's not a race..yet. Grind and check with the valve, so that you get it nice and concentric.
The red arrow is pointing out a low lift killer. All heads have them, we will fix this later. The green arrow is how it should look.
It should look something like below. Also blend into the short side radius (SSR) and Bowl.
Let's test it and see what we've got!
.050 47.8 Peak flow is .050” lower than the OE test with a BC valve.
.100 79.1 While flow was up, you can see a limitation from another
.150 112.5 part of the port, limiting the upper lifts
.200 140.3 We will look at that next.
.250 165.9
.300 187.0 Let's measure the CSA in the pushrod pinch. Red line below.
.350 205.5 width x height at the pinch is 1.629 sq. in.
.400 220.5 The area in the bowl is 2.08 (1.63 sq. x 3.14)
.450 227.1 There's our deficit. The pinch is 22% smaller than the bowl.
.500 226.4 Let's open that up.
.550 222.9
.600 211.5
Above you can see I've got a small SS ruler held in the apex of the outside of the pushrod pinch, and a small square against the gasket surface. Once marked, I traced a line down the gasket surface to provide a reference.
Also too, the valve cover gasket bolt hump protrudes slightly into the port, adjacent to the pinch. Get that out too. This is the smallest part of the port, every little bit helps.
It should look something like this:
bolt boss is smoothed away below. Sideways view below of the pinch. Also the crazy Turn wall.
Grinding in the pinch should be blended into the roof and floor. Caution with the floor though, that area is too big (yes, I know, sounds crazy. My earlier testing prooved that out)
New CSA of pinch:1.840 this is almost 91% of the bowl area. We could go more, staying conservative.
BTW the gasket area is 2.190, but the area upstream from the pinch side is a dead area. Really can't count it. Lets see what it flows.
.050 48.1 well, that sucks. This is a net loss. Something is happening here.
.100 80.6 this is also case and point why a flowbench is necessary!
.150 111.1 You litterally don't know what's going to happen unless you test.
.200 138.2 Now, what do we do? A new better VJ could fix this, it's about time.
.250 164.0 I did notice, however, the port started to get a little noisy.
.300 188.0 This is usually the SSR. But this is also the easiest area to screw up.
.350 206.5 I've been conservative thus far, I'm steering clear of that for the moment.
.400 219.5 let's see what a Valve Job will do..
.450 224.5
.500 218.3 It is also temping to hog off that bulky guide, but since I've seen
.550 216.2 some 'ported' heads out there with the guide intact, It will be educational.
.600 216.2
The VJ I chose to grind will be on the conservative side, mainly cause that's what you'll get at your local machine shop.
With exception of the top cut.
I used a 32° top extra wide to knock off that nasty ledge I pointed out earlier in this article.
I added a radius to the OD of this stone to provide a nice transition into the edge of the chamber.
.060 wide 45° seat and a 60° bottom .100 long. The 60° will be blended into the bowl.
The top green arrow is showing the work the oversized stone did for some unshrouding.
The bottom green arrow is the area some blending will be needed bowl/VJ
The black arrow is showing the nasty ledge has been removed
The white arrow is pointing out what is left of the OE top angle. No harm here. Now for the test.
.050 50.8 Well we started out ahead.. but took a crap between .100~.200
.100 78.1 The port had that dreaded 'draining of the tub' sound between
.150 108.3 .200~.500, so the problem has been exaggerated by the new VJ.
.200 139.1 The SSR is likely the culpret.. one step at a time..
.250 164.0 < Dead even here, up and down, but gained some, and it looses
.300 187.4 above .450, showing a port limitation.
.350 207.0
.400 221.3 Before we attach that guide, lets make sure our opening is up to
.450 228.7 task.
.500 217.0
.550 217.2 The green arrow below shows we will ONLY Gskt match 2 sides.
.600 215.2 Like I said earlier, stay off the floor, lets gain some height.
I know what you're thinking... 'do you really think, that little bit is going to save you?”
Remember, I've done some testing beforehand :)
.050 50.8 while we had to get over .350 to see a gain, it was an interesting one!
.100 78.2 that tiny little bit of grinding got us into the 230 cfm range. Nutty.
.150 108.1
.200 139.6
.250 164.8
.300 188.0
.350 207.4
.400 223.4
.450 231.4 Now, that guide is obese, lets put it on a diet !
.500 223.2 I used the 3/8” oval mostly. Start at the top and work your way down,
.550 220.2 and sweep the parameter. make sure to tie it up in the green circle.
.600 217.6 This is a dead area, and needs activity = flow
.050 50.5
.100 77.5
.150 108.1
.200 140.1
.250 166.3
.300 191.5 < here we can see a definitive increase in flow. The port is quieter too.
.350 213.8 slimming the guide took some of the 'load' off of the SSR
.400 230.8
.450 237.7 I know, I know, some of you are screaming, 'do the SSR!'
.500 229.4 Ok, lets. And lets make a template that will simplify it.
.550 224.2 with a piece of clear plastic, mark as shown.
.600 222.4 quarter the Int valve (white), mark 1/4” beyond to line up with seat
In the middle of the SSR, dig a canal, until the template fits. Like below.
Keep the 'seat' line even with the seat.
Then grind on either side of the canal, like below. Stand the head on end, for easier access.
Blue sharpie shows blend line I ground to. Check from port opening to make sure of your work.
Now for the test:
.050 49.9 well, that felt good, didn't it!
.100 79.0
.150 109.8
.200 142.6
.250 172.6
.300 194.1
.350 216.5
.400 235.2
.450 243.8 < just about 33 cfm from stock, and you can use a cam up to .500 lift
.500 229.6 Don't let the dip in flow bother you, you want to over-shoot your
.550 228.5 max flow so you can take advantage of it. Valve spends very little
.600 226.3 time at max lift. Anything below that, the valve is there twice!
Final port cc's 165.8
stay tuned, exhaust is on the way !
Let's do 2.0 !
Anybody curious what change would give more flow??
What would you like to see?
1. open up the pushrod pinch more?
2. fill in the floor a bit?
3. take more off of the guide? (make it thinner)
4. unshroud the valve more?
5. open up the turn wall?
let me know, this could be fun !
didn't think about that but it would show what each operation is worth...unless...you did the single mod to 3 separate ports to show their individual value.
Working on it. In steps as you said, as I type.:)
Stand by
My apologies to those who have been waiting.. I got flanked by a Fathers Day Cheeseburger!
I think it took almost as much time to edit my photos, as it did to grind/test ! lol
I'll try to do a better job with the body of this text.. everything got all scrunched up in the first few posts..
Pushrod pinch! and it's a pinch too.
The CSA of the pinch, where we left off was 1.84", I got the CSA to 1.95. That's almost .080 wider. BUT, I could not deal with the pinch, without having to deal with the Turn Wall. (option 5 in post #6)
As you can see below.. as I dug out the pinch, at the top, in order to keep the width, I ended up far into the port and Turn wall. (long vertical line)
Once I got that all evened out, I ended up with an anomaly down stream.
As you can see here below. vertical green line.
I think this will work.. (below) green line is in the roof/wall corner.
PR pinch test:
.050 49.9
.100 78.3
.150 108.8
.200 141.2
.250 168.5
.300 192.6
.350 215.6
.400 235.1
.450 237.5
.500 229.1
.550 228.5
.600 228.8
The port air got pretty noisy (turbulent/separation) during the test between .400 - .500. which is why we didn't get into the 240 range like the previous test. Bummer
So there's something going on to upset the flow. Could be in the SSR again, but lets see if thinning the guide will pull us through like in the earlier tests.
Next up! Unshrouding and also some deburing.
I spent some very careful time deburing and unshrouding outside of the top angle and also
on the chamber wall. it's tough to make out in this pic, but I did hit the chamber wall while staying within the head gasket .
Debur/shrouding Test:
.050 50.9
.100 79.1
.150 109.7
.200 144.4
.250 172.2
.300 197.2
.350 220.4
.400 238.2
.450 237.8
.500 230.0
.550 229.3
.600 227.5
The noise I encountered in the previous test wasn't as bad this time around. surprising. only at .450.
What was not a surprise is the low/mid lift flow we picked up. 5 cfm on average
Next, the guide!
You can see where I ground by the shiny grind marks. I blended the wall just a bit too.
I also sharpened the tear drop down stream of the guide.
Guide thinning Test:
.050 50.8
.100 79.2
.150 110.3
.200 144.7
.250 172.9
.300 198.3
.350 221.3
.400 239.1
.450 242.1
.500 233.4
.550 231.5
.600 229.9
Well, got back into the 240's again, even though the port was noisy from .250 on..
There is, however, one test left.
Below in red. I will grind this flat and straighten the common wall..
I will also take a sanding roll to the whole thing, cause this is
just fugly like this. TOMORROW STAY TUNED !
Someone asked to see my playground... well, this part anyway :)
Truly excellent job on the editing!! :):thankyou:
Excellent job all the way around! I just have one small criticism-How does a guy in the corner of his garage use stones (Kwik way or Sioux I'm guessing) for the very important valvejob. Honestly don't take this the wrong way , its a rhetorical question.
Seriously great work though and great thread. J.Rob
Thank you J.Rob
..mainly the grinding part. The intention was to rely upon your local machine shop would give you.
But I also wanted to illustrate the importance of the top angle (larger diameter stone)just to make the point. When a Serdi is used, a second cut would have to be performed to get the width, but it would be a 90°. But, I'm sure you're well aware of that :)
Thanks for the input !
UPDATE !
Looks better, if nothing else..
Look at that crazy anomaly (circle) in the floor !
As I said in post 11, I took out that rough/bulge in the common wall.. and it looks like the big dog finally wanted to take in a meal ! :)
Fix bulge and polish - cause the big dog wanted to eat - TEST:
.050 50.1
.100 79.5
.150 110.4
.200 142.6
.250 171.4
.300 198.1
.350 222.8
.400 242.8
.450 255.8
.500 257.2
.550 254.6
.600 247.5
You know, I figured we'd be kissing the 250 range, but not the edge of the 260 range!
This is in par with some of the prepped EQ's I've seen online. w/2.02 valve
Thanks to everyone for your interest!
I have a project to get done but, hope to get to the Exhaust port later this week.
So don't change that dial !
On my serdi I hardly ever used 90 degrees
you can hit water in the bowl
usually 80-85
Noise gone?
usually 80-85
Noise gone?
above the VJ, and chamber?
Yep, noise was gone... there was some roughness on the turn wall that could have
been the culprit.
Other than the common wall, I didn't do any reshaping.
Great thread!
Any chance of seeing a port mold of before and after?
can't do a 'before'... after? don't have a molding kit.
Yeah, I messed with them 25 yrs ago... they're interesting.
I should drive my 2 sets of LA heads up to you and buy you lunch to look at them . Im sure they (one set at least) are FUBAR (seen here on this board) , other set is supposed to be professional.
