SnowDrifter
1956 Barracuda what pump should i use.
don't want Electrical pump
The 340 pumps put out about 2 psi more than the others, so you gotta be sure that your needle(s) can handle that. I measured 7psi on a 340 once. Same gauge reads 3 to 4 on the others.
and sealed pumps are not clockable. Some have threaded ports and some have hose-nipples, and some have one of each; But they all bolt onto the pad provided for them. and all can be made to work, albeit some easier than others.
The thing is to properly diagnose your system to make sure that you actually need a pump.
Save your money and use Push-Loc hose and fittings. On our race cars we got away from stainless braided and never looked back.Since I have no pump I'm pretty sure I will need one. will be run all new Steel braided from tank to carb. Making my own fittings
I think cost is equal when you figure labor on the solid line if you have to wiggle in-and-out of a lot of places. When you're laying on the ground Is just easier to feed the braided through all the spots. Did you run into problems with the braidedSave your money and use Push-Loc hose and fittings. On our race cars we got away from stainless braided and never looked back.
probly too shoWhy was my posts deleted?
I don’t understand the reply.probly too sho
I didn't catch your message. Perhaps it was too short and got lost in the cloud.I don’t understand the reply.
