ChargedDart75
I could have swore ARP made a set as well.
May be that's who makes these.I could have swore ARP made a set as well.
Would they be the same torque spec as the ARPs?
I'm using one of those as well. I kinda went overkill on my kit. I got the Scat kit with forged crank and pistons. I'm planning on spraying it so wanted the extra strength. Kinda why I'm leery on the factory bolts
Well that would be easier solution. I can use the windage tray on my next truck 360?I don't believe I would run a baffled pan AND a windage tray.
I don't remember seeing a stock bolt with a washer though. Did they make stock or stock replacements with washers? They don't have that classic ARP look from the photo either, so maybe they are a stock replacement.Those will be probably the same torque as factory. They appear to be the factory 340 cap bolts for use with a windage tray. I thought somebody still made them.
Just 4I just noticed the price too. Hopefully that's a full set of main cap fasteners, not just 4.
Seems a bit steep, but if you don't want studs then this is about the only way to go.Just 4
Milodon says 85ft lbsI don't remember either, but I wouldn't over think it. What's the factory torque spec? 85 LB FT. They ain't comin loose. lol
Arp calls for more I think, on the studs.
Is that Biden in your avatar as a psychotic flasher? lol
Yes, to remind people .Is that Biden in your avatar as a psychotic flasher? lol
I torque the ARP studs the same as the Milodons. 85ftProbably.
I run a baffled pan, crank scraper and a windage tray.
And that came straight from Kevin Johnson at I-J crank scrapers.
Pan baffles have nothing to do with windage trays.
OP, what’s wrong with the Chrysler bolts? They are very good. In fact, I doubt the ARP bolts are any better.
Honestly nothing just didnt want to overstressed them. I'm not 100% sure what their strengths are. Like I said it's a 408 with spray. If everyone thinks I'll be ok then I'll use what I haveI run a baffled pan, crank scraper and a windage tray.
Opinions vary. I gave mine and I'm stickin with it. I don't know Kevin Johnson and I don't give a **** who he is.
He gets paid by many high end racing teams and OE’s to fix oiling issues.
You should listen to him. He’s forgotten more about oil, oiling and oil systems than everyone on this board put together and then some.
