Just waking up.Where is everyone?
Any subscription services like that, I use a prepaid visa. Pay the yearly upfront, cancel the card. Prevents this problem. I once signed up for satellite internet that SUCKED. They refused to cancel it. And then kept raising my rates 20 bucks a month at a time. I finally moved and got lucky when they couldn’t shoot thru the trees to get a signal. then they finally cancelled. After that, I never used a card linked to my accounts againAnd here is another scam. You get started then they start taking from your credit cards $200 at a time. Then try to get it cancelled!
Nothing yet. He has some work to do on his end.Any hits on parts yet? The ones with the new buisness?
Dam missed that!!!!!!I am glad a new page started
Maybe this will help...
Coffee is done!
Not open yet it is on the 9thDid you put a bid in on the drill Hoppy?
Those look like the rivets that hold the heat riser passage onto the underside of the intake. You must have found some small ones for ID plates.received some of these last week. They work great putting the early tags back on.
I have some too, but pointy tip.received some of these last week. They work great putting the early tags back on.
