BobW
Curmudgeon At Large
My alternator puts out 15.2 volts pretty consistantly.
The battery is seeing this same voltage!
I've done the relay splice as recommended by @67Dart273 and thought the problem was solved, as I was showing ~14V at the battery.
I checked it again as I was seeing a bit of battery acid on the top, 15.2V!
I have a Tough One P7509 alternator, Advance shows it doesn't fit my '64 Valiant. I found it is for a later model, the one I used was a '76 Duster and Advance shows it fits that car.
I have the older mechanical Voltage regulator, that obviously isn't regulating!
I also have 2 round back alternators that came with the car, haven't tested them yet to see if they work. I'll probably hook them up to se if they have output, and what goes to the battery.
Can I use the later P7509 by using the later model regulator with the triangular plug?
There's a reason I call tis car 'Bitsa'! ;)
Pics of the current setup and the 2 roundback spares:
Oh, Merry Christmas, enjoy, be safe!
