6.1 Hemi 69 Barracuda Fastback Father Son Project
Got a Challenger Console off of EBay
Will try to fit it with the SRT4 seats and new tunnel...
Nice! :thumbsup:
What headers are you running? I sure hope my TTi headers still clear the HP70. Hopefully just taller and not much wider than the 727 pan.
Using TTi HCA61 but haven’t bolted everything together yet. Everything I have read says there should be no problems.
I think the issue with these transmissions is more about height.
Are 68 and 69 A-Body door latches interchangeable?
I know the lock button is located in different locations on the doors but isn't that just a different length rod? Don't see 69 door latches anywhere only 68.
Anyone here used these?
EPAS Electric Power Assisted Steering for the 69 Barracuda
Will be mated to an Ididit Tilt Steering Column, Momo Steering wheel and Paddle Shifters.
Had to make a plate to go on the firewall and relocate the opening to where the steering shaft will clear everything. Used the original firewall steering column plate as a template and made the new with 3mm thick plate aluminum.
Cut it out on my bench router table with a trim bit from Harbor Freight. Worked great.
A 3/4" Double "D" and 1" Double "D", a 3/4" 36 spline to 3/4" DD U-Joint, a 3/4" DD to 1" DD U-Joint, a 1" Bearing at the firewall. Collapsible Steering Shaft with Electric Power Assisted Steering.
Now to shorten and modify the Ididit Tilt Column to fit.
Really happy with the results so far.
Ididit says they will disassemble, cut the column and inner steering shaft down to my measurements for $100.00 + shipping and I can maintain the warranty.
Seems worth it to me.
A few more pictures...
The EPAS kit came with a Plate for the firewall but I think they have "Early A" for all the A-Body Barracudas and not correct for 67-69 Barracudas. So I made my own.
Cut down the stock column for all the test fitting.
When you do a complete Nut and Bolt RestoMod it's expensive...
Partial List for my 69 Barracuda WIP 3/26/16 through today
Power Stop (AR8309XPR) Drilled and Slotted Rotor pair Raybestos Front Brake Pads Raybestos Front Brake Calipers Moog K7040 Strut Rod Bushing Kit 2 of Moog K791 Control Arm Bushing Moog K8243A Cam Bolt Kit 2 of Moog K7103 Control Arm Offset Bushing Kit ARP 240-7301 Torque Converter Bolts Moog K7074 Pitman Arm Moog K781 Ball Joint Moog K783 Ball Joint Gates 32922 PowerGrip Hose Clamp
Upgr8 5 Feet Length Stainless Steel Braided Fuel/Oil/Gas Line Hose (-8AN, Silver)
Aeroquip FCE1834 Nickel-Plated Steel -10AN A/C 90-Degree Female O-Ring Pilot with Service Port
Zirgo 10485 Direct Connect AC Bulkhead System with Jam Nut (-10 AN)
theBlueStone -4AN -6AN -8AN -10AN Braided Fuel Line Hose 10FT -10AN Nylon Braided for 5/8" Tube Size
EVIL ENERGY AN Hose Fitting Adjustable Wrench Spanner Lightweight Aluminum 3AN-16AN Black
5/8 Rubber Hose Connector with Pipe Clamps - 10an Hose Finisher with Screw Band Clamp for 5/8 Fuel Line Hose, 4Pcs/Pack Black Hose Clamps, Great for Fuel/Oil/Diesel/Gas/Air and Water Hose Pipe
Performance Tool W5201 270 Pc HNBR O-Ring Assortment
Aeroquip FCE1833 Nickel-Plated Steel -08AN A/C 90-Degree Female O-Ring Pilot with Service Port
Zirgo 10491 2 Port AC/Heater Bulkhead Kit (10AN/8AN)
Aeroquip FCE1014 Reusable Aluminum -10AN Swivel Straight Fitting
Black Aluminum 2 Port (1-L 1-L) Ac Air Conditioning Heater Hose Firewall Bulkhead
Earl's 1004ERL Vice Jaw
Kraken Automotive - 10AN Stainless Braided Hose for Fuel, Oil, Coolant and Air (10 Feet)
90 Degree -10AN Female to 10 AN Fuel Hose End One Piece Full Flow Swivel Seal Hose Fitting Adapter Black Aluminum Anodized
Zirgo 10488 Direct Connect AC Bulkhead System with Jam Nut -6 AN
Vintage Air 35813-VUG 10-Straight Beadlock O-Ring Fitting
2004 Neon SRT4 Seats Pair
BBK Performance Parts 1792 Power-Plus Series Performance Throttle Body
2 of Moog K7293 Leaf Spring Bumper
2 of Moog K704 Ball Joint
2 of Moog K3180 Control Arm Bumper
AMD 800-1370 Steel Trunk Floor Pan - Full 1967-76 Mopar A-Body
2 x Year One 17x9 wheels
Ididit Universal Tilt Floor Shift Steering Column Length: 32" 1120320010
EPAS Performance Electric Power Steering Conversion Kit Mopar A-Body 3002
Rechrome Both Front Vent Window Frames
Straighten and Rechrome F/R Bumpers
1.03" Torsion Bar Master Kit - Polygraphite - A Body (TOR4820P)
Bilstein High Performance Shock Set - Front & Rear (BIL7056063)
Greasable Control Arm Pivot Shafts
SPC 94460 Mopar RH Adjustable Upper Control Arm
SPC 94461 Mopar LH Adjustable Upper Control Arm
StopTech 928.63017 C-Tek Sport Brake Kit- Fronts Only
1967-1976 Dodge A Body Adjustable Strut Rods from Hotchkis Sport Suspension
1967-1972 Dodge A-Body Sport Sway Bar Set from Hotchkis Sport Suspension
Mopar Thrust Angle Shims for Hotchkis Sport Suspension Leaf Spring Kits
A-Body Offset Spring Hanger/Shackle Kit 1/2" hole
Leaf Spring Perches (Pair)
Custom length Axles and Brake adapters, lines, seals, gaskets
shipping
Rear End Narrowed, perches moved, drain plug added, welds smoothed
Built Torqueflite A-727 Full Manual Reverse Valve Body + Mopar 10-3/4" High Stall Torque Converter
1967-69 Plymouth Barracuda Carbon Fiber Dash Panel
Alternative Blasters
Goodmark RF fender patch rear
USCT1M1004 67-75 Dodge Plymouth A Body Level 2 Chassis Stiffening Pack
USCT1M1802 67 to 75 A-Body Transmission
USCT1M1305 67-75 A-Body Radiator Core Support Replacement with Adjustable Width
LED Tail Lights
1 x Leather Wrapped Tuff Wheel 1 x 306-TB Mopar 1969 Plymouth Barracuda Taillight Bezels 1 x 306-L Mopar 1969 Plymouth Barracuda Taillight Lenses 1 x 306-T Mopar 1969 Plymouth Barracuda Taillight Lens Trim 1 x 305-T Mopar 1969 Plymouth Barracuda Back-up Light Bezels 1 x 308-DL Mopar 1967-69 Plymouth Barracuda Dome Light Bezel 1 x 331A-6SET Mopar 1967-68 A-body Chrome Automatic Console Plate Kit
Hurst Shifters 69520001 Tunnel Patch W/ Template - Mopar A-Body W/ Tko
6.1 Hemi Biscuit Style Motor Mounts with biscuits
Billet Oil Catch Can fittings, hoses and mounting bracket used
Trunk Divider Hinge
U-Bolts [47] Axle Tube Diameter:: 3 inches
RF Fender, R&L Door, 68 Deck Lid
2 Year One Rallye Wheels 8x17
A-Body Hotchkis Leaf Springs
Rotisserie, Valance Brackets, Mopar Front Brackets (These I've sold already and subtracted the sale price I recouped)
Milodon 31000 Pan, 13331 Pickup
Remanufactured 6.1 Hemi Engine Complete (Some of the accessories not used will be sold)
Classic Auto Air - Air Condition Evap and inside vents controls
Tires Riken Raptor 275/40 17, 245/45 17 Tire Rack
340S Emblems Pair
VIN Tag Chrysler Dry Transfer
69 Barracuda Side Marker Set Front and Rear
American Auto Wire classic update wiring 510603
1/4 vertical seal
hood to cowl seal
door and trunk seal
roof rail seal
quarter glass hw 80084
side glass hardware 280102
side glass roller hw 280101
door end caps
door jamb u seals
TTI 61HC-C5, Polished Ceramic with Thermal Barrier,
BO125, Header Bolt M8-1.25 x 25mm
GA-HG61, Header Gaskets
GA-RG30, Collector Gasket
RED30x25x9, Header Reducer Adapters
G2 Axle and Gear Rear Disc Brake Conversion Kit 96-2049-DB
7" Round Semi-Sealed LED Clear Headlight Conversion
A-Body Automatic Center Console
Parking Brake Handle Lever Duster Dart Demon A-Body 68-74 (May try to incorporate a floor mounted hand E-Brake between the drivers seat and console)
1969 Plymouth Barracuda Cuda Floor Pan Exhaust Hanger Bracket NEW MoPar
Windshield Washer Nozzle Pair LH & RH Sides for 05-10 Jeep Grand Cherokee New (Filled and smoothed the Cowl Vent opening)
1966 67 68 69 70 Barracuda Cuda 2 Headlight Adjuster & Spring Kit New MoPar
1969 Plymouth Barracuda "A" body Body Bumper Kit New MoPar
Mopar 68 69 70 71 72 73 74 A-Body B-Body C-Body Window Handle Crank Spacer
Mopar 68 RoadRunner Satellite 69 Barracuda Finish Panel Trunk Hardware Fasteners
Mopar 68-74 Window Crank Handles Set Four Cuda Charger Challenger SuperBee NEW!
DMT MOPAR 67-69 Barracuda MEGA Splash Shield Set Kit Seals FOR AUTOMATIC TRANS
Data Plate Screws
Caliper Brackets Pin Type
Transmission Oil Pan Bolts
Shift Lever
Radiator to hood seal
Energy Suspension 9-9121G Black Polyurethane Bump Stops
1969 Dart Barracuda Vent Wing Window Tinted Glass
Noico Black 80 MIL 36 SqFt Car Sound Deadener
Mopar 66 67 68 69 Barracuda Dart Charger Road Runner GTX Trunk Lock + Key NEW
Passenger Manual Mirror
Drivers Remote Mirror
Door Handles
Flip Top Gas Cap
License Plate Lens
Mopar 67 68 69 Barracuda Cuda Fender Bolt Kit 1967 1968 1969 NEW
Front Bumper Bracket Frame Bolt Set 66-72 B-Body GTX Charger Road Runner
1967 1968 1969 1970 1971 Dart Duster Demon Barracuda Kick Panels
TPS Throttle Position Sensor For 98-07 Dodge Durango Dakota 3.9L 5.2 5017479AA
OEM Idle Air Control Valve IACV 4861552AC For Various Jeep Dodge Chrysler
MoPar 1960s-'70s TorqueFlite 727 Transmission ACCESS or INSPECTION PLATE ! O.E.
NEW STARTER MINI MOPAR DODGE PLYMOUTH 318 360 400 HIGHER TORQUE
MoPAR 67-70 STEERING BOX BOLTS CHARGER CHALLENGER PLYMOUTH ROADRUNNER GtX HEMI
68-74 Mopar A B E Body Cuda Leaf Spring Clamp Rubber Insulators
60-76 Dart Duster 64-69 Barracuda 1.5" Rear Leaf Spring Bushings Prothane 4-1017
Mopar 727 Auto Transmission Shift Lever
Mopar 67 68 69 Dart / 67 68 69 70 71 72 Valiant Hood to Radiator Seal NEW
1967 1968 1969 Dart Barracuda Vent Wing Window Tinted Glass
Mopar 64-74 Charger Roadrunner Cuda Challenger All Radiators Mounting Bolt Kit
Mopar 66 67 68 69 70 B-Body / 67 68 69 70 71 72 73 74 75 76 A-Body Mirror
Mopar 67 68 69 70 71 72 73 74 75 76 Dart A-Body 68 69 B-Body Manual Mirror NEW
Digital Guard Dawg i-key Push Button Start Passive Entry System
69 GTX, Road Runner, Charger, Barracuda Side Marker Set Front and Rear
1964-76 Mopar A, 62-72 B, 70-74 E Body Lower Control Arm Stiffening Plates 14 ga
Mopar A B E Body 11 inch Disc Brake Caliper Mount Brackets with Bolts and Parts
1968 69 70 71 72 Mopar A-Body Wiper Pivots Dodge Plymouth Barracuda Dart
Mopar Dodge Dart Anco 15A wiper arms Plymouth A body 66 67 68 69 70 71
USA RESTORATION*" SERVICE"* FOR MOPAR A-BODY DOOR HINGES DART DUSTER DEMON
A PAIR(2) RV gas strut shock spring lift Damper aftmkt rep SPD 2300-90
1968 1969 Barracuda Rear Valance Panel with Tips AMD
Mopar 727 Stainless Braided Flexible Firewall Mount Transmission Dipstick 25-3/4
12" Long 3/4" DD Stainless Steering Shaft 1" DD x 3/4" DD U-Joint Kit
2017 Dodge Challenger Scat Pack Center Console Automatic
NOS Glass Channel Weatherstrip 2932230
NOS VENT WINDOW HARDWARE! (LEFT & RIGHT!) - MOPAR DODGE CHARGER DART GTX TRUCK
RESTORED 3 SPEED WIPER LINKAGE 67/68/69/70/71 dart/demon 67/68/69 barracuda
SHI-195-40R RH FRONT FLOOR PAN
AMD-106-1267-S BUMPER BRACKETS
AMD-450-1370-R AMD Rocker Panel Right Plymouth Barracuda Coupe
Sherman Fender Patches 250-36L
POF-120-10003LWR CNRTL ARM PIVOT SHAFT KIT
AMD-A-270230HOOD HINGE RETAINER CLIP
QA1-52313K FRAME STOCK
AWW-500931 EXTERNAL BATTERY Terminal
Energy Suspension Torsion Bar Dust Boots 5-13101R
March Performance Serpentine Kit, MCH-40700-08, Chrome AC Manifold MCH-418-06
Auto Twirler Chassis, Car Body Dolly Cart
Sonnax T35-ALFY-07 - Flanged Yoke Tr6060, 8HP70, 8HP90
DA696BLK Dash pad for 1969-1976 A-body models. Color : Black
E43P Flat finish sill plates for 1967-1976 A-body models. Sold as a pair.
MY2 RH fender emblem, 1967-1972 A-body models, reproduction.
VC92 Reproduction "Formula S" fender emblem for 1965-1968
VC148 "Barracuda" fender emblem for 1969 Barracuda models.
P2785791 "Plymouth" hood nameplate
AH765100 Premier Perforated grain headliner for 1967-1969 Barracuda fastback models. Color : Black
RX42B Rear window reveal molding clip set for 1968-1969 Barracuda fastback models.
SKA68A 117-piece interior screw kit for 1968-1969 Barracuda fastback
WCRD690 Reproduction windshield gasket for 1968-1969 Barracuda fastback models
SM669 A/T shifter mechanism with woodgrain shift knob for 1969-1970 A- and B-body models.
DB3847 Rear window gasket for 1968-1969 Barracuda fastback models.
A975025 Reveal molding clip set, all models, reproduction.
MCK71 Dark argent center cap kit for use with YearOne cast Mopar Rallye wheels.
BH340B Trunk lid finish panel for 1969 Barracuda models. Black
FW974 Hood pop-up spring for 1967-1974 A-body models.
C316TK Technalon heavy duty car cover fits 1967-1969 Barracuda.
MP722BLK Rear lap belt in black with a black textured lift latch for 1968-70 Mopar A-body models.
MN722BLK 3-point conversion front seat belt set in black 1968-1970 Mopar A-body models with bucket seats
EP10B 2.5" i.d. Exhaust tips-pair, 1968-1969 Plymouth Barracuda models and 1970 Dodge Dart Swinger models. Polished stainless steel.
A0269P Exhasut tip hanger pair for 1968-1974 A-body models
Won't be using these M&H Wire Harnesses since we got the American Auto Wire classic update wiring 510603 that includes all these harnesses in their kit.
All from Year One
- RL41 Rear light harness for 1969 Barracuda fastback.
- L38445 Dash-side A/C and heater harness for 1968-1969 Barracuda and Dart models.
- L38569 Backup light harness for 1969 A-body models built up to November 15, 1968 with A/T.
Running Total $42,705.12
Each item's price is included in my excel workbook but doesn't copy paste well...
~200 separate line items!
Also a lot of items that were trial/test and then not used so removed... Some of the items listed above may also end up not being used because we found something we liked "Better" or just changed our minds... Like the Pat Blais Built, Zero Mile, RVB, Manual Shift 727 w/Chrysler Stall Converter $1859.97 + Core. Being replaced with a 2018 8HP70 8-Speed...
Ha! There's another $800 ($500 + $300 Shipping from Texas) to add to my list - 8HP70 Trans with Torque Converter.
Oh, and the US Car Tool Trans Tunnel $649 and the US Car Tool Trans Cross Member for 8HP $295.
Still need to add the Sound German Automotive PCS (Powertrain Control System) $1000 and PCS Paddle Shifter $550
Make that $45,499.12 and counting...
This is why you should never build one and never ever keep track of how much you spent...
Original Car Purchase Price, Bodywork, Paint and Labor not included...
There are more than a few items I didn't add to the list because sometimes I'm just too lazy...
Did I mention this will be my kid's car when finished? Call me crazy, I know.
He will be on the hook for 50% of the total cost. I think he's getting a pretty good deal.
He paid for the 6.1 and a few other items along the way but he is still in school and this past summer we was not able to work his summer job of the previous 3 years due to Covid-19
Snohomish County Public Works, Road Maintenance Division
Currently in the process of making mounting brackets for the AC Condenser.
They are the Aluminum pieces test fitted at the top and bottom.
After I have the condenser located I can route the AC plumbing.
Going to hide the lines as much as possible. Some will go between the inner and outer fender.
shipping
LED Tail Lights
Trunk Divider Hinge
340S Emblems Pair
1/4 vertical seal
hood to cowl seal
door and trunk seal
roof rail seal
door end caps
door jamb u seals
Data Plate Screws
Shift Lever
Door Handles
Flip Top Gas Cap
License Plate Lens
All from Year One
Still better than an opioid addiction and they don't keep receipts.
Happy New Year!
Got the AC Condenser where I want it and got a start on the plumbing.
First to make a hole for a 90* elbow to go through.
Test fitting with rubber lines that were included with the kit before making up the braided stainless lines that will be in the Engine Compartment.
Hard lines will run between the inner and outer fender.
Need to enlarge the hole a little bit more but need a new big step bit.
Will put a large rubber grommet in the hole after I enlarge it a little more.
O-Ring Female to O-Ring Male Elbow on the outside to a 90* down with service port inside.
Thought about a bulkhead in the core support but I'm liking how this is working out.
Next will be a flex line to a bulkhead through the inner fender.
Don't know if I could be much slower but at least it's progress.
Bending the hard lines to fit should be interesting...
Hydraulic Punch Driver Kit from HF.
First time using it. Got to admit, this thing works great.
1/8" thick core support, no problem. Nice clean hole. Forget the Step Bit.
Now to see if I can come up with a single bulkhead fitting for the inner fender for other hose...
Are you planning on allowing the one line to lay on top of rail? Engine vibrations most likely will cause line chafing or if using SS braided line mess up pretty paint at the least. Might consider 90° from compressor then a 45° from engine compartment to condenser? Just wondering what your plan is. I'm sure it'll be a good one.
I was thinking about either floating or Plastic block type spacers for both hoses...
I have lots of different fittings to play with. Maybe floating with a couple plastic straps like the one supporting the heater hoses in my E-Body...
Either way, definitely don't want any friction between hose and any metal edges or painted surface.
Good call though. :thumbsup:
Made some more holes today. I'm really liking the Hydraulic Hole Punch Driver.
First for the Heater Lines. Drill Pilot holes first.
Then punch them out.
What it looks like from the inside.
A few pumps of the handle...
And presto... we have hole!
Rinse and repeat...
We now have two Holes!
Add a pair of bulkhead fittings.
Quick test fit with some heater hose.
Not too shabby. Think that will do just fine.
The back side of the heater lines Bulkhead.
Leaving the inside heater line plumbing for later, I moved on to Coolant Line Bulkhead install.
Same process but had to flatten the little channel for the bulkhead plate. I used the Hydraulic ram with 2 flat surfaces facing each other to flatten it out. I'm liking this tool more and more. Wonder what else I can think of using it for? I got some dimple dies to use with it but no dimple plans yet... Anyway, here are the coolant bulkhead fittings installed.
continued...
Another view
Inside
Heater fitting circled in yellow and the AC fittings in red.
Next up... bend these to fit as needed.
Should be interesting. The -10 will not need much bending but the -6 line will be going all the way forward and around the corner in front of the core support to the Dryer.
Will start it at the dryer being sure to put enough bends to make a nice fit.
The -10 line will stop short of the core support and connect to a 90* bulkhead fitting.
The 90* fitting can go right where the -10 line ends...
That's all for now.
Back to the day job tomorrow... Not as fun but the pay is a lot better!
----o00o--'(_)'--o00o----
Nice work. I like the tool too. Here's a thought, although you probably already have a plan, anbout protecting the refrigerant lines in the wheel well, before you make-up the ends consider slipping some rubber hose over them, or fab up a removable shield of sorts. Some "things' on the road flying up from the tire are pretty sharp and hard. You wouldn't want to not have A/C after all your hard work. The high psi side/liquid line should be insulated anyway. Keep up awesome work. Oh, and I'm sure you'll support those long lines somehow as well, so they don't flop around and stress out connections.
