[SOLD] 70 DUSTER “Semi-Survivor” 318/B5 Early Low Option Car
5150DodgeBro
Pittsburgh PA
Rating - 0%
0   0   0
New FABO member...Sorry-I’m kinduv old school and have never found time to be active in the forums. I guess it’s about time after 40+ years of playing with countless Mopars. Please be patient with me if I somehow mess up or don’t provide rapid response to questions, pics, etc. Thanks!
1970 Plymouth Duster “Semi-Survivor” 318/B5 Low Option Car!
****Please read entire ad*****
(I try to spell it all-out to answer as many questions as possible)
An unrestored/mostly unmolested (one repaint) garage-kept southern car....
I’m offering-up now before spring when I will continue to make repairs/improvements.
DRIVE ENJOY AS-IS NOW OR A NICE CLEAN-SLATE FOR A TRULY EASY PROJECT
THE GOOD:
NO SALT! APPEARS TO HAVE ALL IT’S ORIGINAL, NO-RUST SHEETMETAL:
fenders and aprons, doors, rockers, quarters, trunk extensions, etc., etc.
Great frame and as well in all areas where these cars are prone to rust.
Good glass and trim. Perfect original grille. Nice clean interior.
Solid floors were cleaned and POR painted. Repair patch in passenger footwell.
I have pictures showing exceptionally clean inner-structures: quarter/dog legs, wheel openings and door bottoms. No rust repair detected other than the floor.
This WAS an original B5 car that was repainted in a darker shade of blue over 20 years ago when it came to PA from Tennessee. Paint finish is mediocre at best, but this ‘ol Duster still turns heads going down the road. The factory-original B5 finish remains in the engine bay, jambs and trunk area. The original spare tire, bumper jack and trunk mat are in great shape. The blue interior is very clean and shows well. Correct for 1970 rally wheels have been added.
Truly a low-option, 1st year Duster w/pristine build sheet and fender tag.
Fewer than 500 miles the last 15 yrs. Only 150 miles since PA inspected last yr.
Showing 105k miles, generally a driver/survivor that was cared for and not abused.
Numbers matching 318/904/7.25 manual steer and brakes.
Runs, shifts, stops very good and does not smoke.
Newer Parts and Repairs:
Brand new Legendary front seat upholstery (on order) w/nice orig headrests.
Brand new P225/70R14 tires and AMD Rear Bumper.
Front Brake Drums, Wheel Cylinders and Shoes.
Battery, Alternator and Neutral Safety Switch.
Rebuilt Carb, Fuel and Oil Filters.
Plugs, Wires, Points and Tune.
New original-style mirrors.
Additional Parts Available (for addl $ and purchase of car-otherwise not for sale)
A-Body 8.75 Rear and Gears.
‘68 340 Block, Caps, Crank, X Heads and adjustable rockers.
Original Stock-Steel 14x5.5 Small bolt wheels and Plymouth Dog-Dish Caps.
THE BAD:
NEEDS DRIVERS SIDE FREEZE PLUGS (rusty, but still hold coolant as of 12/26)
Speedo needle bounces a bit at low speeds.
Choke thermostat not working or adjusted right.
Gas gauge not working and heat riser rattles a bit.
Factory AM Radio not wired, working condition unknown.
One rally wheel should be replaced (IMO) due to previous overtightening.
Evidence of moisture trapped under the floor covering. Scale removed/patched.
Fair-to-poor older paint finish as mentioned-but can look better w/some finesse
Ordinary signs of age and usage...typical scratches and imperfections.
Paint probably looks better in pics than in person, like a 10-15 footer.
A few cracks in dashpad and factory rubber floor covering.
Have the trim rings but each have dents/wrinkles.
Minor wrinkle on the tailpanel and front bumper.
As spring approaches, repairs/improvements will continue and price will be less negotiable. FOR BOTH OUR SAKE, BE AWARE...I have no problem keeping this car if I do not get offers at or near what I’m asking. I like original/survivor cars but I’m inclined to start making changes on this one if I decide to keep it...
Clean, original ‘70 Dusters are very hard to find. Here’s your chance!!!
$16500/OBO
Good morning and Happy new year. Could you please post outside pictures of the car ? 16,500 is like 22,000 Canadian,just saying. So before we go any further.... cheers
THE GOOD:
THE BAD:
$16500/OBO
Happy New Year and thanks for the interest. I intially posted a ton of pics and then it limited which ones were posted. I was able to edit and get a couple exterior shots back on if you did not see earlier. I’ll try to upload more later. Let me know if youd like to see something specific too and I’ll see what I have. Thanks
I have replied to this person about this car on Facebook and also CL and got no replies, hopefully it will be better here.
Sorry but I’ve had a few people that are just throwing numbers at me without even seeing the car. If you’ve read the ad, how can I help you?
The friend who posted on Facebook for me was getting ridiculous DM’s even though the ad clearly stated to call me...as does the CL post. So, I had her pull the FB one so she didn’t have to respond anymore. If you have legit questions, please fire away...I’m as honest & transparent as you’ll find (please read the post) And if you saw the CL ad, you certainly can find me...most long-time Mopar guys in the ‘burgh know me too. Anyway Snewpy, was there something I can answer for you about the car?
Hello all. Thought I had addressed most questions with my lengthy post and pics, but I’m being asked for more specifics....
Indeed the car was repainted approx 22 yrs ago in a darker shade of blue, over its original sheet metal. It was not a base/clear or a high-end job. Still shines a bit and could be buffed to a better shine if desired. There appears to have been NO rust work done to the car at that time or since, other than a patch to the passenger-front footwell and some pinholes elsewhere in the floor.
The original factory B5 paint remains on the backside of hood/trunk, engine bay, trunk-area and jambs. Paint on motor was poorly touched-up at some point, but is the original, great running 318.
I have 2 matching build sheets original to the car. The nicer of the two from the backseat was pictured behind the springs before removal in the original post. The other is torn all along where the springs made impressions, but is otherwise good and can be easily pieced back together. I do not yet have a pic of the fender tag. The car is in winter storage. You may be able to see it still attached in one of the previous posts.
The original front seat is out of the car awaiting new matching upholstery from Legendary. They are months behind (ordered 12/1/20) but when received, will go to the buyer. The seat itself is an excellent core, the burlap isn’t even torn. Tracks are really nice too. The rear seat is also original and cleaned up very nice, has some hard-to-see spots that I could not get out. The only interior pieces re-dyed were the package tray (wrong color), defroster vents and seat belt buckles due to scratches. I did buy 2 cans of OER 330 Blue Interior paint and was going to spray the headrests due to sun bleach, but have yet to do so. They’re actually pretty nice as-is. All belts including the shoulder belts cleaned up very nice and have very good chrome.
Hope this covers it...thanks.
