Effective stroke has to do with cam timing evens IIRC & got this right. AJ will splain it good!
That cam, in the right setting, is indeed an outstanding cam. (I run something very similar in a Hydraulic roller) In the wrong setting, it’s pathetic. This is why AJ runs to the calculators. They can realllllly bell dial in what your looking for even if you don’t know what you need.
If you have all of the other information about the car& engine but are missing the best possible (or as close as possible) cam timing events (cam size included) the calculators point the way. IF! You follow the calc exactly, I will be a custom grind and may have a grinder scratching there head. LOL!!!
Also beware that what technically or scientifically works out as the best cam may not be what you like to drive around in. The engine may not idle nicely, drive around in idle well, drive nice below the point where the torque picks up and becomes nice to drive in... etc.....
This is why there are a bunch of cams that look very similar but react unbelievably different. And also why every time someone asks for advice on a cam, there is a different answer for almost every reply.
Go on and fill out the on line forms for a cam recommendation to 10 cam grinders and receive 10 different suggestions.
I have a good understanding of cams, not a great one. I’ve been knee deep in conversations with grinders and racers. I’ve come to the conclusion that knowing everything for everyone is impossible and it is not possible to get the right scientifically or via calculators the right cam but for only one person. Myself.
No matter how you explain your decision to another, they will more than likely tell you that you screwed up.
Some will tell you that you don’t care about HP (to small of a cam) because of your choice, then next guy will ridicule you for the lack of torque it’ll make. (To big of a cam) or the lack of midrange torque. (Wrong timing evens)
Make the best educated choice possible, stab it and run it. If you like it, enjoy! If not, there easy to swap out.
