beanhead
Well this is an old thread and 'mopar65' I hope ya got it fingered out by now. I just noticed this part in the highlight above, and maybe it was just a type-O....but if that was true the spacers were in backwards. Mike's spacers typically set so the bigger side is toward the valves, as we need to move the shaft up and back toward the intake.Yes I have the B3 kit from mike. I have the shims with the short side facing the valves. Yellow duster the problem I am having is if I get the roller rocker centerd on the valve, the push rod Rubs the side of push rod cut out. Now if I shim the rockers wear the push rod is centered in the cut out in the head, the roller moves over close to edge of the valve stem. Now I dont think the roller will come of the valve it's just closer than I have ever ran before. The heads have been torqued down, but the engine has never been started . But if I have to pull the heads to grind the push rod tunnels more. No big deal about buying some more head gaskets.
It's been awhile and I'm sure you're all good now but I figure a little clarity helps in case some other antique post reader stumbles across this later..
