capnswanny
Active Member
It all worked out fine for my son, he drove the GMC instead!
Inductive clamps are fairly common these days.I'm going to pick up an 30A ammeter gauge tomorrow,
Since current draw (and battery voltage) increases with engine RPM, do you think it could be something in the coil/distributor circuit
Doubt it.
The over voltage is only a VR cir issue
Have you measured the voltage to the field wire when the charging voltage is 12 to 13 and again when it is 15 to 17?
Best guess is at 15 to 17 the voltage will be close to 11 to 12v. And when charging at 12 to 14 it will be in the 6 to 9v range
What was wrong with it?the original (dead) VR with a like VR from NAPA.
Need to see what makes the VR-106 a 'heavier duty' regulator to know if there is any functional difference.a heavier duty Standard VR-106.
That can be a very good clue about a problem in the system.
It's possible the oxidation where the resistors are rivetted continues into the connection. Other than that, if the points are good, its good.
The heavy duty VR has the screw adjustment. I think I've seen that in the service manual on the Essex built regulators. As far as I know they work the same way.
Since the fusible links aren't melted, and the point are fresh, there's no reason why it shouldn't work.
If there is a problem with votlage climbing beyond 14.9 its most likely that the regulator is 'seeing' the wrong voltage, or the somehow the regulator is being bypassed.
Shop manual has the details of the regulators. I snipped some of the pictures to use in this post
Blowing voltage regulators
The drawings in the post that follows came from this booklet.
Alternators and Regulators 66-11 (Session 228) Master Technician's Service Conference
A quick check for VR causing lack of to the rotor is to place a jumper from the "ign" side (power) to the controlled side "field".Thanks, I replaced this one because it just stopped charging period
That might be for the optional alternators that were wired a little differently. I've seen some Chrysler info on them but can't recall where off the top of my head.Here’s a pic of the VR106 next to the NAPA replacement. Ohm readings are a little different than the “original”, and one end of the coil is tied to the sense terminal through a 10 Ohm resistor? The coil wire is heavier gauge, and a little better wrapped.
Only if you know the battery is close to the same voltage as the alternator is producing.I’m going to check the drop from batt to VR at when I get back to it
I find it amazing that the modern replacement VR are mechanical like the 54 year old OEM units.
One would think that electronic VR guts could fit nicely into the same housing.
Otherwise measure the difference between the alternator output voltage to the voltage the regulator is seeing.
The VR should maintain a constant voltage to the system assuming the alternator can supply sufficient current.
Essentially the VR will increase or decrease the voltage/current to the field to maintain the correct output voltage from the alternator.
Think of it this way.
Your battery is a bucket.
It has a small hole in the bottom, (that is the load of the car, headlights, ignition, etc)
Your alternator is a pitcher,
when the engine is off no water is being poured from the pitcher into the bucket. So the water level in the bucket starts to drop.
With the engine started, you are pouring water from the pitcher into the bucket. At idle you are pouring a very small amount of water into the bucket, not enough to equal the amount going out of the hole in the bottom of the bucket.
Now you are at a higher rpm and you are pouring more water from the pitcher into the bucket faster than the water is leaking out the hole in the bottom, and the bucket is slowly filling up. to keep it from overflowing you start pouring a little less water into the bucket. Untill you are able to pour just enough water into the bucket to maintain the level in the bucket.
You are the VR!
By tipping the pitcher more or less you are changing the volume of water going into the bucket.
The fact that the pitcher is constantly pouring way more water into the bucket than is running out the bottom is the issue, nothing that the engine or the rest of the car is doing can cause that
EXCEPT...
If the voltage to the VR is low it will try to tip the pitcher more than it should and over charge.
To check that, check the voltage going into the VR when it is charging at 15 to 17 volts
I know that I am interchanging current and voltage when talking about the VR, but if the input voltage to the VR is low it will think that the alternator needs to increase in voltage so it will cause the field coil to be fully energized more of the time causing a higher output voltage.
I hope my wandering example is not too confusing
Can't say for sure about the 5A,Question for you, is 5A normal draw by the coil in the ON key position (not running)?
It’s less than 1A with the distributor disconnected from the coil
Found this on a web site:
"How many amps does a ignition coil draw?
Ignition Coil (single oil-filled coil older vehicle) - 3 to 4 amps."
So 5 does not seem out of line.
but with the coil disconnected from the dist. there shoud be no draw from the coil.
How and where are you taking the amp reading?
