Another Blueprint Engine Delay
Ricks70Duster340
My "Blue Bondo Baby"!
Sisterdale, TX
Not ragging on BPE, but my 408 build has been delayed again. Ordered it on 2/2/21, and still waiting on parts. They got a shipment of camshafts but rejected them because they were not up to spec. Appreciate a good build, but.... ! At least it gives me time to play with other areas of my car, so not totally dead in the water!
It's all that @Johnny Mac guys fault. Seems ever since he started there, things just keep gettin better for that company. Why anybody wants to break ground making actual good products these days is beyond me.
That said, I'm sure they'll get the stuff in. Everybody's runnin behind with everything. I think the USPS, UPS, FEDEX and all the rest have used this virus crap to just drag ***. That's my story and I'm stickin to it. lol
I agree. My Fedex ground guy said not long ago he had a large delivery area. Because everyone is ordering over the internet now, he only has a couple of roads and they have split his territory up with 4 other guys. Shipping companies are booming!
So True
They're all behind, but the USPS is the worst, because they are refusing to hire extra help.....at least in our ares. Our regular delivery girl talks about it all the time. She says their package delivery quotas keep going up and up and they're hiring no one.
Wonder where those camshafts came from?
Doing everything we can to support demand, and you are correct, we have a very stringent QC inspection process. Everything from material to specs are verified with every parts shipment. Noone is perfect but we do everything we can to catch any issues before they even hit the floor, then of course verified on dyno, and verified again with filter inspection and 20 other checks.
Appreciate you guys sticking with us on the delays. Fords are taking the longest. The mopars aren't much better between the edelbrock move, and cams.
You guys have no idea how much I appreciate the kind words, and being patient with us on the build times!
I believe they use Comp cams.
The BOM is a comp core on that one. Since they are delayed like the rest of us, we ordered samples with our same spec elsewhere. Those are the ones we rejected
Best of luck. I’m in the steel industry and our lead times went from a few days to over a month with strict allocation on some material. No signs of improvement either.
Can you elaborate on the specific problem with the cam. Metallurgy of the core? Heat treat? Accuracy of the grinding? Other?
Thanks.
...Bill of materials.
There is a worldwide shortage of all raw materials. Lumber is skyrocketing big time. Steel prices are all jacked up. Electronic IC's are in short supply. Get ready for everything to go up in price and likely never come back down.
Thanks Johnny. It's wonderful that BPE has developed many of their own parts to ensure quality instead of relying on inconsistent 3rd parties. Seems like folks will not slow down ordering quality BPE engines, so wondering if you are considering expanding the foundry to make heads & grind your own cams? I know this would not be an overnight process, but you are already on your way to being a "one stop" engine builder.
We cast our own blocks and heads for much of the Gm and Ford lineup. It's a volume driven investment. I'm sure you can imagine at 70 engines a day, what percentage are GM, Ford, then Mopar.
Agree on the volume investment needed, but if the major components for a Mopar build are not readily available, that puts a stop on any assembly process like mine. New orders only compound the problem until there is a massive backlog, canceled orders, and vastly reduced future orders. The parts you've developed for the BPE brand have no doubt been high quality, so why not develop your own Mopar heads & cams to ensure the same & better quality and performance? In time, the lower Mopar engine volume builds might even be augmented by people ordering your parts directly from you instead of going to Comp or Edelbrock because of the availability & performance. A new aspect of the BPE enterprise to handle major component purchases by end users/builders?
Because no one will buy them. You can’t make enough of them to make any kind of profit, and if the block isn’t 900 bucks the Chrysler guys won’t even have a sniff at it. And if they do, they’ll ***** because it isn’t finished machined for that price.
It’s a losing proposition.
Thanks.
This info likely won't be divulged! BUT, if this gives a clue, the flat tappet cam cores are not formed well. The parting graft from the mold actually affects the "rate of lift" when cycling the cam during the degreeing process. This issue is not on all the lobes, luckly was on the one I chose to do the degreeing from. The lifter follows the lobe edge, due to the built in lobe taper, as it rises and then follows the flaw, the lift rate actually backs off and then rises again, see pic. Cam # 20-212-2 .
