Straight Slant Six Thermostat Housing Question
Hyper_pak
Old School Chrysler Fan
Desoto Texas
Does anyone know if there is a straight housing application that will work on a slant? I have heard about 2.2 or Magnum housings that might work. Just trying to get a little information before I start ordering parts I can't use. I need to come straight out of the head to go to my aluminum radiator. Thanks
Do you mean pointing STRAIGHT towards the driver's side?
All these have the same gasket so perhaps another application has a straight housing
CADILLAC 1963-1985
CHRYSLER 1979-1989
DODGE 1960-2003
FARGO 1962-1972
JEEP 1995-1997
OLDSMOBILE 1958-1963
PLYMOUTH 1960-1989
Cadillac housing
Rusty, Yes, straight out, not up.
Thanks phista, that might help me.
Well........here's the dilemma. The slant six I believe has the same bolt pattern as the rest of the Mopar engines and those on Pishta's list, however, the actual thermostat size is the smaller 2.125" and not the larger one like the V8s use. If that Cadillac housing uses the small one, it will work. There aren't but two main size thermostats I believe.
Rob, that big ol' '64 Caddy 429 uses the same stat as the /6. I think it's good to go.
